Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
How well will the LPE 219 cam work for my car?
Old Sep 23, 2000 | 09:57 PM
Dan87IROC-Z's Avatar
My mods are listed below, what do you think, too much maybe? If its too much, what cam will work well for my car?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.3 @ 97mph
(corrected for elevation)
Old Sep 24, 2000 | 12:30 PM
Jarod87IROC
Guest
Posts: n/a
You still have your stock heads? I was told that single pattern cams like the LPE 219 really need some good flowing heads. If you're keeping those heads you'd probably be better off with a dual pattern cam that has more duration on the exhaust side. Like maybe the LT4 Hot Cam w/ 218/228?
87 IROC
350 TPI 5-speed
Edelbrock Aluminum Heads, LPE 219 Cam, Super Ram, SS Wheels, Graphite Leather, etc. Click here to see the rest.
THE crew: ICON Motorsports
Old Sep 24, 2000 | 04:31 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I have the same cam in my Camaro, but with a Q-jet carb.
You will definitely need a good set of heads and a SuperRam intake. The cam is meant to pull to 6000rpm in a 350, which isn't possible with the stock-style TPI setup and stock heads. You should also go to a 3-1/2" exhaust and get a 52mm TB too.
It is true that the cam needs heads with a really strong exhaust port to clear out the cylinders.
Paul Huryk, billionare in training.
Monkey Guy Racing
Almost part of the moderately infamous NJ in-your-face all goomba crew
Do it right the first time.
Paul's home page
1985 IROC LG4 POS Best: 15.20s at 92.1mph
1984 Camaro 350 LG4 Best: 12.21s at 121.7mph
The smart person pays for something today so that more is received tomorrow.
The ignorant person gets something today and hopes to have enough money to pay for it tomorrow.
Old Sep 24, 2000 | 11:14 PM
I am not going to by new heads, a super ram, or a new TB, if I had that kind of money, I would by a mimi ram since it is much better. The question was what cam would work well for my car now.
L98 TPI 350 (5.7L)
Old Sep 25, 2000 | 08:43 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
If you are going to run stock heads and stock intake then you cannot go radical on the cam choice. A cam that is well matched to the stock heads and intake would be a cam with NO MORE than 210º of intake duration and around 220º of exhaust duration at 0.050" lift. Have the cam ground on an LSA of 112º. Lift should be well under 0.500" because the stock iron heads don't flow well at 0.500. I would choose lift aroung 0.460". The stock iron heads have a really weak exhaust port which is why I am noting a dual pattern cam with a good sized difference in intake to exhaust duration. BTW - You'll need to swap springs in order to accomplish this swap. If you don't want to swap springs then look for a cam with around 0.440" lift. You might be able to get away with 0.450" lift ... not sure.
Personally, I wouldn't swap the cam until I was ready to swap the heads.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.587 @ 107.97mph (1.710 60ftr) on the long runner setup.
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels. Stock Wheels. No Weight Reduction.
Gunning for NA 11's with the MiniRam II and Hooker LT Headers.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
