Will the MSD-8366 Distributer Fit on my 350 TPI
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have a chance to get one dirt cheap will this fit?
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
If you're running the stock manifold base, then yes it will work. If you have the Edelbrock base, you will have interference due to the 8366 being about a 1/4 inch shorter than oem distributor (Measured from dist/gasket seal surface to the bottom of the plate that the cap screws to. This is also caused by the Edlebrock manifold has a higher #7 runner (which is the rear-most runner port on the driver's rear of the manifold) port.
The interference doesn't allow the distributor to seat on the gasket, which if you clamp down on the tie down bolt, you'll damage distributor gear/oil pump. You could try grinding some material of the top of the runner port, but this will have to be carefully watched. I was leary of doing this when I originally did my engine install.
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
KevinP92Z
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
The 8366 distributor should work fine on your TPI engine. I had one previously on my LO3 Formula and it worked great. It had to be removed when the ignition module burned out and took the wiring in the distributor with it. After trying to fix it with replacement parts from MSD it never worked right again.
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,no cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit,MacEwen White face gauges,84 T/A cold air induction air cleaner.
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
I've got one in mine and it works great. I have an L98 5.7 TPI. Just be careful about the orings on the shaft. Don't know how, but I ended up tearing one last time I put it in.
KAM
KAM
Sanjay
Aug 12, 2015 03:41 PM
