Duralast CMax Brake Pads - are they ripping us off? (pics)
Car: '84 Trans Am; '88 GTA
Engine: Vortec 355ci TPI
Transmission: TH-700R4
This is partially a review and partially me asking for advice.
I just picked up a set of Duralast CMax brake pads (ceramic) for my GTA (stock disc brakes) after the wear indicator on my current pads (Duralast CMax) began screeching. So after inspecting them here's what I found:
My current disc pads were worn down to 5/32", about halfway. It didn't make sense to me that the wear indicator starts screeching at the half-life of these pads so I checked the new set.
The new set measures 5/16" and sure enough, the wear indicator is about 5/32" in height, about halfway. (Pics for comparison)
This is my first brake job, but for the life of me I can't fathom why Duralast wants us to change our brakes halfway through. My previous set of brakes were installed at the shop and they lasted about 4 years. My current set only lasted about 1.5 years and I really don't wanna drive around with that PITA screeching when I still have some life left in the pads.
I'm thinking about just grinding down the wear indicators a bit further down to get more use out of these pads, but I'm not sure how much more I should grind them. Any advice?
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Duralast CMax Brake Pads - are they ripping us off? (pics)
5/32" is just a hair over 1/8", which is the wear limit on most brake pads, IIRC. That extra 1/32" is to give you some warning before the pads are at their limit so you can drive the car for a few days till you can change to pads or get it to a shop.
Regardless of the wear indicator's depth, your old pads are cracked pretty badly and should be replaced anyhow for safety.
ok thanks for the heads up. but I still don't figure how these brakes lasted way less than the last ones. are there longer lasting brakes out there?
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I use Ceramic = http://www.oreillyauto.com/site/c/Br...ectCeramic.oap
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Go with Wagner thermo quiets. Best brakes iv ever used.
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Wagner Thermo Optional Ceramic Quiet pads at Oreily are $55.99 a set for the front
http://www.oreillyauto.com/site/c/de...0068&ppt=C0009
Rockauto has them for $28.18 shipped to my door?
Both part number QC154
Woah...
Woah...
Transmission: 5-Speed Manual
Woah...
Woah...
I can understand lower but almost half price? Thats pretty low.
Car: 1987 Pontiac Trans Am/GTA
Engine: L98 350 TPI,
Transmission: 700-R4
Axle/Gears: 9 bolt w/ 3.23 posi
They usually buy the over run parts cheap and can sell them for less and still make a profit. I buy a lot of parts from RockAuto. I've always liked that they have the parts I need and it doesn't break the bank.
Car: 83 z28
Engine: 305 cross fire
Transmission: stock
Axle/Gears: stock
Wagners come with radle clips
Car: 1986 Trans Am
If your looking for quality auto parts, Autozone is not the place.
They sell off shore manufactured parts to sell at an economy price.
If you want quality pads that will perform well, look at EBC, Wagner, or Ac Delco Durastop. I'm sure there are other good brands, but these were the ones I have had good experiences with.
Car: 1990 Camaro Iroc-z Z28,1987 Camaro
Engine: 406 Super rammed SBC, LT1 355
Transmission: 4l60E, 700R4
Axle/Gears: disc brake 3.27 9 bolt posi,10 bolt
vette brakes swap over pretty easy on to our cars thats what im running work great
The issue for me isn't how well they perform, it's how prematurely Duralast wants me to toss em out. Are all other brake pads out there designed to begin screeching when there's still 50% material left?
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Why do you care about a free brake job every two years?
"Part Number: DGC154
Warranty: Limited Lifetime
Application: With 1 piston caliper"
-- Joe
I do a brake job every two years anyway, like preventative maintenance.
Eric-86sc
04-03-2016 03:52 PM
