ANNOUNCING GTA 17x9 MESH WHEEL SETS!!!!
#201
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
Re: ANNOUNCING GTA 17x9 MESH WHEEL SETS!!!!
I jumped on the web to see if i could find some pics to compare. What do you all think?
and
and
#202
Did ANYONE ever get a weight on these things?! Several folks have bought them but no one weighed them? What about brake clearance issues... Are there any? I'm weighing the pros and cons here between the two 3rd gen specific wheels vendors around here. I like the LOOK of these more but if there's a significant weight difference and they won't clear C5 brakes then I'm gonna have to go with the others. Btw, I'm looking to buy soon.
#203
I don't even own a scale. I don't think home scales are all that accurate under 30-40 pounds anyway. My car has stock brakes.
Oh and trust me, in real life you can really, really tell a difference between the 16s and 17s visually.
#204
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
#206
Well I jumped and got the gold ones. However I didnt find my wheel spacers in any of the packaging so that's rather disappointing. Tires will be arriving Thursday so this is all I currently have...
And weighing them on my bathroom scale they were 21.5 lbs
#207
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I do beleive these should not be a problem for clearance. I know for the ROH wheels that were 9.5" wide they had a problem rubbing, so they needed to be spaced out 1/4" I thought these were 9" wide, so I would think they should be fine.
#208
My spacers came in a separate box with the centers and lugnuts I ordered at the same time.
#209
So they do need spacers? Interesting...
#210
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Does anyone know if they will clear LS1 or C5 vette brakes? Dont know if I missed it or not.
#211
I think I will go with the OE ZR1 Wheels 17 by 11 in back and 17 by 9.5 in front 315 35 17 in back and and 275 40 17 in front.
#215
I had to stay square for autocross or else the car would push real bad. You have to totally re-tune the suspension if you go un-square.
#217
#218
Car: 1992 Polo Green RS Z03
Engine: L03 - 5.0 Liter V8 TBI
Transmission: MD8 – 4 SPD Auto
Axle/Gears: GU2 - 2:73 Ratio
Yes they do need the 1/4" spacers up front. Wheel hoop would touch a flange on the front strut and the steering end link.
They do use the stock or OEM style center cap.
#220
Here are pics of how close the wheel is with the 1/4" spacer.
#222
Engine: 4++,350 & 305 CIs
#223
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
looks good on the blue one rdhanded2
Can you elaborate some on the work (challenge) you had with that please?
Square is referring to front and back being the same dimensions I suppose? Interesting.. You'd also have to re-tune an setup tuned for un-square although using spacers to ultimately come out with the same wheel position?
#225
Engine: LS1 / L03
oh wait, i just realized your original post..
so you were saying that were the same tire sizes you're running and hence required mods that you discribed, with the 17" mesh wheels discussed in this thread?
That is what I went with size wise. Be ready for the pain in the butt it is to tuck them and get the fronts to not rub in sharp turns. It was a challenge but I got it done.
#227
#228
Engine: LS1 / L03
That makes sense.. so your statement of "square" was more referring to tire size (width) then I take it.
#229
Both width and height. Raising the rear end of a car makes it understeer more.
#230
A modification I did have to make was on the spacers. The bevel on the hole for the hub was not big enough, so I did have to take a die grinder & dremel to the hole and flare it out more so that the spacer would lay flat on the rotor hub.
#231
New shot of the Polo Z03 running the 17 GTA wheels.
#233
Engine: LS1 / L03
yeah, looks great!! could be slightly lowered for my taste however
#234
1 Post
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
When are the 18"s being released?
#235
God I could definitely consider a set of 18x9s or 18x9.5s. Hardly any good HPDE tires left in the 17x9 range. The Nitto NT05 275/40s are the best tire of the available bunch. And the 16x8's have even less choices.
Hate that I need a rim upgrade just to run some sticky tires. Direzza ZII Star Specs aren't available for 17x9's.
#236
Aka 17x9 275/40's on each corner.
Not square would be running say 275/40's up front and 315's out back.
#240
You know what really sucks? By the time they came out with these most of the good tires had moved on from the 17x9 sizes. All of the awesome sizes now require you to be with a 18" or 19" rim.
If I had a ton of money I'd throw a set of these on the GTA backed by Nitto NT05's or Conti DWs as the "daily driver" combo. I always loved the look of the stock crosslace rims.
#241
That's what I get for being an early adopter! Oh well, I needed tires last year and wanted to move up in size.
#242
1 Post
#244
Car: 1992 Camaro RS 25th Anniversary
Engine: 305 TBI
#245
Found some interesting uses of GTA wheels... these are 16x8, but might be neat to try on the Hawks 17x9.
This one had the lips hand polished to a bright shine, repainted the center, and then used chrome center caps. The gold looks a little deeper than the photos posted here, but it's hard to tell with online photos:
