I rally want this
Car: 1986 Camaro IROC-Z
Engine: 350 C.I.
I rally want this
Is there anyway possible for this (Edelbrock 7109: Edelbrock Performer RPM Air-Gap LT1/LT4 Intake Manifolds) to work on my camaro I have a 88 sbc Gen I and I'm want to keep but change the TPI or something similar but better performance. Need help.
Engine: 350 C.I.
Re: I really want this
I want this (Edelbrock 7109: Edelbrock Performer RPM Air-Gap LT1/LT4 Intake Manifolds) is there any way possible for this to work on my camaro I have a 88 SBC GEN I. Would really love the help.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: I rally want this
Is this the one = http://www.summitracing.com/parts/edl-7109
When guys decide there going to be here for a while then its common to post some info about your car.
Simply go to USER CP
then
EDIT YOUR DETAILS
then fill in the last 4 lines at the bottom of the page.
Car =
Engine =
Transmission =
Axle/Gears =
If "everyone" did this it would make it so much easier to make suggestions and help them with their questions.
Thank you
then
EDIT YOUR DETAILS
Car =
Engine =
Transmission =
Axle/Gears =
Thank you
You can modify the LT1 style intake to fit, but it takes quite a bit of machining.
You're better off getting a TPIS Miniram
Bolts right up, but needs the additional fuel rail which pushes the cost to around $1200 for the whole thing.
