Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
What is the best fuel sending unit for 89 trans am
Old Jul 24, 2025 | 08:03 PM
rander's Avatar
What is the best fuel sending unit I can get for an 89 trans am with a 350 in it? I can't find one by Delphi, AC Delco or GM Geniune.
Old Jul 24, 2025 | 08:19 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: What is the best fuel sending unit for 89 trans am
Those are long gone. I've used a Spectra, some people don't like them, but we don't have a lot of choices.
Old Jul 26, 2025 | 07:55 AM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Aeromotive makes one and Holley does as well. You could also fabricate one fairly easy
Old Jul 26, 2025 | 08:15 AM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
I have an aeromotive unit. It works great but, it only has send/return/vent lines. Idk how that would work for emissions stuff(idk if you care about that). I think the stock harness/relay would need an upgrade. I think it pulls up to 12-15 amps and needed 10-12 gauge wire. I forgot what I installed at this point but the specs are aeromotives site.
Old Jul 26, 2025 | 08:32 AM
thatsupnow's Avatar
Can this feed/return fittings be swapped out for bigger fittings like -8 ??
Old Jul 26, 2025 | 08:44 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Obviously NOS is best, keep digging, sometimes you can get lucky.
Nos parts from sock, pump, sending unit and 89-92 1LE tank.
Old Jul 26, 2025 | 08:45 AM
Car: 82 TA
Not really. The fittings are removable but they would neck down if you installed 8an. So you would have a point of restriction. Idk how significant that restriction would be. This is the top of their stealth system that is good up to 850hp (na) and 700 (forced ind) I'm using it on my 550hp blower setup and it's been great but it has its limits.
Old Jul 26, 2025 | 08:52 AM
Car: 82 TA
Mr fancy pants here! You always find and post the coolest NOS Stuff! It looks like you have an arsenal of 1le and firehawk treasures. It's really cool. How do you find all this? Obviously it's out there but you seem to be finding and collecting all of it! It's cool
Old Jul 26, 2025 | 09:02 AM
chazman's Avatar
Axle/Gears: BW 3.45
Man, Tony! You always find the coolest stuff.
Old Jul 26, 2025 | 10:34 AM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
Racetronics has good stuff
Old Jul 26, 2025 | 04:42 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
I put a delphi in mine a few months ago, no problems so far but it isn't exactly a confidence inspiring brand these days
Old Jul 29, 2025 | 12:40 PM
69-er's Avatar
Sticker shock...
https://www.ebay.com/itm/25703969065...Bk9SR-aunfSKZg
mack1985transam
Carburetors
Jul 14, 2012 07:37 PM
ringo234
Sep 29, 2005 06:06 AM
