AFR Heads
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
You will need to get the 190's to match the runner hieght of your TPI baseplate.The 195's have a taller runner.That is the only dfference between the two,the taller runners on the 195's,they flow the same CFM for the most part.I am very happy with my AFR's,good choice!
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Forgot to mention before,talk to a guy named MARK at AFR when you call,very knowledgeable.He helped me set my heads up nicely and also many of my friends (we are huge AFR fans),he will get you set up with what you need.Hope this helps some more.
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
