Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
I need ac delete pulley part #
Old Mar 4, 2002 | 08:52 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I could not find the part number for the a/c delete pulley for the tpi motor on the board any where. I went to gmpartsdirect but it would not bring it up.
The guy at the local dealer was not sure about the # and was going to charge about $60 for it . This seems a little steep!
thanks for any help!!
Old Mar 4, 2002 | 08:55 AM
vjo90RS8's Avatar
Car: 2002 Z28
when i got mine it was part number 10055890, but if you type that into gmpartsdirect.com, it comes up as "water pump pulley" now and i dont understand why. So you might just want to email them. Mine came to about 55 with shipping.
Old Mar 4, 2002 | 09:58 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
I have the part number at home... Ill post it after work for ya.
Old Mar 4, 2002 | 10:52 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Mine has the number vjo90RS8 posted:10055890
Got it for about $50 at dealership.
-Rich-
Old Mar 4, 2002 | 03:14 PM
yeah, those numbers the other 2 guys listed are correct.
Old Mar 5, 2002 | 08:14 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
thanks guys!!
I called my local dealer and he said he could get it for $45.00. plus tax. Not To bad of a deal.
Did anyone notice a difference in hp when you got rid of the a/c.
I was realy moving it out of the way to make it easier to work on my car, but if it reduces drag on the crank and frees up some hp then great.
Old Mar 5, 2002 | 10:41 AM
vjo90RS8's Avatar
Car: 2002 Z28
It probably frees up a few HP, but i did it at the same time as my headers and cat-back, so dont really know for sure. But if you remove everything (condensor, compressor, accumulator, evaporator, AC box and all the hoses), you are removing about 30 or more pounds off the front end. It also frees up so much room in the engine bay.
Old Mar 8, 2002 | 01:02 AM
Kandied91z's Avatar
why would you guys remove the air in your cars, i could understand if you couldn't get it to work or the car was strictly for the strip; but you honestly think it will make any difference in power other than 1 or 2 points. besides cleaning up the engine bay sum i can't see the point.
not to put anyone down, i just don't understand the thinking behind some of the ideas. to each his own i guess.
Old Mar 8, 2002 | 02:46 AM
vjo90RS8's Avatar
Car: 2002 Z28
first of all i have ttops and windows. second my air conditioning wasnt even charged and why spend money recharging it with expensive R-12 when i am not even going to use it. Third, if i am not going to use it when why have all that weight seeing in my engine bay, not to mention how much space it takes up. So taking all these things into mind, why wouldnt i just rip it out. The engine bay looks so much cleaner and i have so much more room to change spark plugs, etc.. I think it was well worth it. The HP gains , if any, are just a bonus, not like i did it for the extra performance.
Old Mar 8, 2002 | 07:33 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
the extra room was the reason I was removing mine. and It needed charged up too. I will only be driving the car to the strip, and on short trips around here. I have the T-Tops and window tint so I can stay cool. When it get hot this summer I will be driving my other car.
It really does make a difference when changing plugs and wires!
Old Mar 9, 2002 | 08:12 AM
91rsrider's Avatar
i have three reasons for removing my a/c.
1)weight
2)more engine bay space,tidier appearance.
and 3.......T TOPS!!
and the a/c on makes my motor overheat like a ****
Old Mar 10, 2002 | 03:43 PM
Kandied91z's Avatar
damn people an your t-tops!!
Old Mar 13, 2002 | 09:43 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Yeah, I love my T-Tops.
Thanks guys for the part #. When I get done with some more mods, I am going to the track. I will post times when I get them.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
1nastygta
Aug 8, 2015 07:38 PM
