Starters
Car: 1992 RS
Engine: 406 Stealth Ram
Starters
I think I am going to be needing a starter soon. I want to get one I can use with my 305, as well as with my 406 I am building. I would like to get one of the mini starters that jegs has, but there are so many. This one http://www.jegs.com/cgi-bin/ncommerc...%202409%202684 looks good, and has a better pice than some of the others. Any suggestions? Thanks!
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I have that started on my solid roller 10:1 406 motor. It is a great piece and one of the least expensive starters out there. I am pleased with mine and would recommend it!
1991 Formula w/ K&N filter running 11's. MAN THAT IS SOME FILTER!
Car: 1991 Camaro Z28
You could also just buy an LT1 starter from the Chevy dealer or a local auto parts store. It is a high torque mini starter like the one you want. It might not have quite as much torque as the one you are looking at but it is still more than adequate and is cheaper. I have this starter on my car because the stock one won't fit the T56 bellhousing and it is a great starter. Just an idea for you to consider.
1991 Z28 - 350 TPI, T56, McLeod street clutch, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
Gunner242
Dec 25, 2015 04:49 PM
