Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Comp cams
Old Mar 13, 2002 | 08:27 PM
robbob's Avatar
Comp cams
Any one else have problems with their cams in 305 lg4's non cc particularly the xe256h-10?
It made my car run horrible,stalling really bad idle etc.I ended up having to put the stock cam back in.
Old Mar 13, 2002 | 09:49 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
What are the specs on that cam? I wouldn't put a cam as causing that to happen unless the duration @.050 was like in the 290's! Sounds like a vacuum leak unless that cam is huge but I don't think it is.
Old Mar 13, 2002 | 10:24 PM
robbob's Avatar
It is as follows, in 212,ex ,218 lift ,.447, .454, 110*
This is the cam they(comp) recomended with stock heads,and then their web site says not to use stock springs etc.I think the problem had to do with the vacuum it created?
The car was also hard to turn over,like it had really high compression with a too small starter,had to do full throttle starts.(new battery)
Old Mar 14, 2002 | 06:38 PM
robbob's Avatar
Well it turns out that the Moron mechanic school instructor goofball didn't check for a vacuum leak(said he did,but lied)and didn't do the timing right.His exact word were "it's not my car so I don't give a ****"
So now the cam is out and the old stock one back in.
Nice huh!
Old Mar 14, 2002 | 06:39 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
wow that sucks. I thought it sounded like a vacuum leak. I would put that cam back in and make him do it for free!
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
sandman92084
Sep 12, 2015 10:27 PM
masonta
Sep 1, 2015 06:40 PM
