Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
anyone using Moroso deep sump pan
Old Apr 6, 2002 | 10:57 PM
L98FORM89's Avatar
Car: 1989 Formula 350
Engine: 355 HSR
Transmission: Rossler 700R4
Axle/Gears: 9 bolt/3.27
I want a new one and was looking at the Moroso street/strip deep sump oil pan.Is there anyone using it and if so were there any problems with clearances or leaks, etc.Any help would be appreciated. thanks Stewart
Old Apr 8, 2002 | 08:16 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I run the deep pan #20180 on my Z with no bad side effects.My car is lowered an inch with Hotchkis springs and still no problems,I hit my scattershield first.The pan sits even with if not a bit higher than the crossmember,so you will hit the crossmember first anyway.Only problem I had was the y-pipe (SLP 1.75" headers and y-pipe) where it crosses over in front of the pan was a little tight.I dimpled the y-pipe here and there and have not had a problem yet in the 2 years the motor has been in..no leaks,or anything for that matter.I like the pan and am very happy with it,highly recommend it on a high winding motor that sees abuse..hehehe
Old Apr 8, 2002 | 02:33 PM
L98FORM89's Avatar
Engine: 355 HSR
Thanks. What engine are you running?Summit says the #20180 is for pre-1980 blocks?I wonder if my slp 1 5/8 y-pipe is the same.
Old Apr 9, 2002 | 02:36 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I am running a '72 350 4 bolt block.In its current state it is a 355 with some bolt on goodies..AFR's,4340 forged bottom end,the small stuff.I don't know if the y pipe is the same size or not between our headers,yours MAY be a little smaller,but either way it won't really be a problem.You just need to get the pan that works for your motor (1 piece seal) and you will be good to go.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
