ebmiller88 = good brake vendor
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
I recently bought a C5 caliper / LS1 rotor setup from Ed Miller to fit under my stock 16" rims and am very pleased.
Ed Miller is on the forum as ebmiller88 and sells very complete and high quality brake kits for our cars.
The kit came with everything necesary for the swap, right down to the Earls braided lines. The kit was fully test fitted before shipping and fits like a glove.
He was able to customize his kit to what I wanted without any problems.
I would recommend him to anybody looking at new brakes.
This thread pretty much covers the buildup of my brakes, with some pics at the bottom of the first page and on the second page:
https://www.thirdgen.org/forums/brakes/308508-c5-calipers-ls1-rotors.html
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
I second that motion. Ed does good work. Lets continue to shop at home.
Car: 1988 Trans-Am GTA
Engine: 5.7L TPI
Transmission: WC-T5
Axle/Gears: BW 3.27
i also had a great transaction experience with EBMILLER88. will deal with again for sure
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Did the kit include modified spindles and caliper brackets? I am close to going with a Z06/C5/LS1 front brake set-up and I really would like to use EB's stuff.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yes it does. My "Standard" kit will include the following:
Modded spindles: cleaned, modded, drilled, tapped, and painted;
Hubs, zinc coated with new studs installed;
Brackets, zinc coated;
Timken bearings and seals;
Raybestos rotors usually, GM rotors in some kits;
All brake parts and hardware;
GM ceramic pads standard (LS1 and C5 kits only);
Earl's front braided lines;
GM banjo bolts and crush washers;
Grade 8 hardware or Metric equivalent;
Parts list and install guide.
Hubs, brackets, and bearings are INSTALLED FOR YOU!!
I'm really thinking of offering powdercoated spindles standard but I'm not sure yet. I can also offer powdercoated calipers, zinc washed rotors and such. PM me for more info.
Glad to help guys.
Ed
Glad to help guys.
Ed
1 Post
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
Hey Ed, are you getting my PMs? I sent a payment through paypal for the c5/z06 hubs, brackets, spindles, lines last week. Just making sure you got it.
Thanks,
Peter
Thanks,
Peter
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
I agree that Ed does outstanding work (even for us G-body guys). Ed, I need to get my old spindles back to you; Katrina put a big hold up on everything.
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I've not bought brakes from Ed, but I did pick up my current rear end from his house. Just as he said it was, have had no trouble.
I saw his shop, does very nice work. I'm hoping to buy the C5/LS1 setup from him this summer sometime.
Car: 91 Z28
Transmission: built 700R4
I bought a partial kit from Ed, I already had the calipers and rotors. He was verry helpfull with the many questions I had while instaling them.
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
ED,
I will probably be needing hubs and brackets. How much for them and are they new hubs or used ones? Do you do any coatings for the brackets or hubs? I have already ordered a set from another member but I have not seen anything in 5 months.
Let me know.
Let me know.
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Ed is a good guy to deal with.
I got my LS1 stuff from him to, least the hubs and brackets
later
Jeremy
later
Jeremy
1 Post
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Originally Posted by FIRECHICKEN
ED,
Let me know.
Let me know.
1 Post
Car: 1986 camaro
Engine: 383 sbc
I purchased spindles, hubs, brackets and hoses for my c5/z06 swap and Ed's quality is far beyond anything that I have seen on the market. Everything is just perfect and couldn't be happier! Thanks ED!
Peter
Peter
sailtexas186548
01-19-2016 12:21 PM
