B&M Megashifter
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
B&M Megashifter
Well I got a used one all installed in my car, I got the brackets and cables in the right spot as far as i know, got it shifting real easy and smooth tonight but one problem is...when i rachet shift it i drop it into one...but it takes two bumps on the shifter to get it to to go into second, then two bumps more for it to go into 3, but once in third it shifts into forth fine but it it wont bump into neutral afterwards
im gonna call B&M monday and see what if they have any suggestions, just figured id ask here first!
Car: on the street, duh
Engine: 5.7 L 4 bbl bored out
Transmission: i dont know
Axle/Gears: stock
Re: B&M Megashifter
i do have one of those, but i havent had the car running yet to kno if that is a problem for me, i kno its hard to move it from all the way back to go foward
Car: 1989 IROC
Axle/Gears: 3.42 Auburn
Re: B&M Megashifter
The problem seems to be with mine is that the plates got bent because the shifter was not mounted perfect. So i took it out bent the plates away from each other so they werent touching and mounted it better. Haddent messed up since so i got my fingers crossed.
jimbo
Aftermarket Product Review
Mar 14, 2001 05:35 AM
