SuperRam & Functional Ram Air Hood?
Car: 1985 IROC-Z Z/28
Engine: Brand new GM 350
Transmission: Stock (for now)
I know theres a big brew ha ha about how Ram Air may only work at 11 billion miles an hour but that aside I was wondering if it's possible to have a SuperRam on a 350 85 Camaro with a Ram Air hood and still use the special Ram air, air filter it comes with.
The hood: http://www.ramairhood.com/store/scri...p?idproduct=15
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
im not really sure but im putting stealth ram on my car within a month and i tell you what im going to make it works whatever it takes but i think it will cause it puts the TB in the stock location if it works with TPI why wouldnt it?
yeah I think reguardless there is probobley a way to make it work I was just wondering if anyone has done it in the past. If not I'll be doing the same thing, just making it fit some way.
Car: 1991 Trans-Am
Engine: 350 TPI (SLP mods from factory)
Transmission: 700 R4 (built with 2500 stall)
Axle/Gears: 3.23 Disc Posi
I am doing the same as Dans, getting stealth RAM with the RAM air hood, and as he said....if the throttle body is being bolted in the same place no matter what the base plate is, it should still work out right. If not, then maybe nly a few minor adjustments.
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
mustangman65_79
Aug 11, 2015 03:17 PM
