Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
problem with my stealthram fuel lines
Old May 14, 2005 | 02:51 AM
89yellowroc's Avatar
i am installing my stealthram and i was putting my fuel lines together using 6-an fittiings but i ran into the problem of my fuel lines coming into the car or different sizes and i bought the fittings the were used on the stealthram website. the return works fine but the supply doesnt fit. the line coming in is to big for the fitting does anyone know what fitting i need or am i overlooking something
Old May 14, 2005 | 08:28 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I think the bigger one is a 15mm. I will have to check when I get home tonight. The one I ordered was a power steering fitting.
Old May 17, 2005 | 12:01 PM
bubba353z's Avatar
Car: 07 Honda CR-V
Engine: Yes, there's one in there...
Transmission: One that shifts itself
The factory supply and return lines are different sizes. Are you hooking into the factory connections, or doing something custom?
Accel and Earls make fittings to connect the factory Saginaw fitting to 6-AN lines. I just bought myself a set this weekend, but haven't started the swap yet.
Old May 17, 2005 | 01:34 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, two different sizes. I've had some trouble getting the proper feed side part as it sometimes gets mis-packaged. Here are teh Earls numbers:
9894DBH Female 14mm x 1.5 to -6
9894DBJ Female 16mm x 1.5 to -6
RBob.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
