Very clean LT1 Intake & head swap
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I wanted to post some pictures of what I think is a really clean, well done LT1 swap.
tpi_roc, board member and moderator on the TPI board, did this conversion on his 1985 Iroc. He's using factory ported LT1 heads and intake manifold on a traditional SBC.
You will see how he ran the coolant lines (which is one of the major turnoffs to an lt1 swap) to make it a little more neat, plus the intake to head mating was factory (no drilling, etc).
Car: '91 TA vert
Engine: turboLSx
That waterneck bugs the crap out of me. Where are the lines routed below it? Wouldn't it have worked better just getting a 90 there into the radiator?
By clean do you mean just washed?
Looks nice. He'll have to change his name to lt1_roc now.
Car: '91 TA vert
Engine: turboLSx
I wasn't doubting the functionality of it at all. I was just saying it looks like your running it around in a circle. Was there anyway to get a neck pointed towards the driver fender and run a 90?
I plan on locating a better water neck as the L98 leaves much to be desired in this configuration. I just cut off 3" or so from it and used it for mock up purposes. I'm sure an older shorter SBC neck would work better or even one of the really expensive swivel type. I'll eventually find something a little nicer and anybody else could easily do the same. Another option would be to cut it, turn it, and weld it. For now it works and I'm not too worried about it.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
tpi_roc has gone through TPI on a stock motor, tpi on a 355 with sportsman heads, then a converted LT1 manifold for sportsman heads, and now finally the LT1 manifold + head swap. I can't think of a better more complete way to perform the swap. I can't want to see time slips.
-- Joe
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
that does look very good. little bit easier since you have the coolant ports right on the front of the heads. theres another member on here that made a bracket so the thermostat housing sits right by the throttle body (braket bolts to acc. bolts on the brackets). thats what i was going to do with mine. last year i made a bracket that used the cruise control holes and i ran the lines back behind the master cylinder, looked ok, but kind of cluttered
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
i think my install looks good and neat
Car: '86 Iroc, '87 Iroc Vert
Engine: 350 TPI, 305 TPI
Transmission: T5 in both
Axle/Gears: 3.73, 3.45 both LSD's
Originally posted by rsn932
86IROCTHD- looks verry nice
the only thing I don't like is how the spark plug wires go halfway over the intake...it's like they are dominating the engine bay. Other than that, awesome!
I only hope when I FINALLY get finished with my LT1 Intake swap it looks as good as that.
P.S. I like the MAP sensor eliminator plug. I already did that on mine with a standard pipe plug. It looks much cleaner that way.
Car: 88 Trans Am
yea that plug was last min thing....... need to take the intake back off my heater hose fittings in the back are leaking... i would suggest having them welded or something mine are seeping a bit..then i will have that plug welded in and start porting... and the wires are the moroso ultra 40's over the valve cover style...just need to clean them up and what not a bit....
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally posted by tpi_roc
This thread was about LT1 heads converted for an early small block, and fitted with an UNmodified LT1 intake. Yours are LT1 heads too?
Although his setup does look "nice", its not a LT1 "Intake & head swap", so it don't belong on this thread.
In the future folks, if your going to add to this, please ensure its a Intake & head swap. As far as I know, unless proven otherwise, tpi_roc is the only member who has actually done this conversion. (even though I see a lot of posts talking about doing it)
-- Joe
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
that is the title,so it would have to have Lt1 heads along with the intake the only mod can be for the distributer and water fittings
well then any gut/SOP feeling of what if anythign it was worth?
I think in one of the threads you mentioned that you're running out of fuel much sooner, which could be an indication of either making more power or a worse BSFC, but assuming that the BSFC stayed similar you could probably predict the power increase by how and where you ran out of fuel and how that compared to duty cycle before the swap...
Take that whole paragraph with a grain of salt.
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Is there any advantage to doing this swap? Not saying it isnt well done because it is. Im just wondering if the effort really is worth the time involved just to convert the heads over. Or just running a straight LT1 or just the intake conversion with aftermarket heads would get you their with less effort. I guess a break down of all the parts and price involved would really be nice to see. To me time is money and if he did all the work himself was it worth the time you put into it.
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
The advantages have been listed in another huge thread about the topic. I believe there is a link to it in the top of this forum.
Car: 1997 Corvette
I'm curious, are there any performance numbers/improvement numbers on this setup yet?
and another one edited my post. I should have numbers in a few weeks on a moderate 355. Thread Starter
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally posted by DuronClocker
I tried to reply to this once already, but one moderator jumped on me because I must be taking his fire away from being the only one doing this
and another one edited my post. I should have numbers in a few weeks on a moderate 355. Let's keep it clean, technical, and elite on this board, and maybe the morons will stay in the TPI board where they belong.
If your doing an lt1 head/intake combo swap, we'd like to hear about it.
-- Joe
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
i am going this route with my motor, and i am wondering has anyone tried to mill top of the mounting flange to be parallel with the head sealing surface? i am thinking about it because it would give me more clearance for the center four bolts on pre'86 heads.
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
I've got a setup like this for sale on this board. The heads need to be finished.
https://www.thirdgen.org/techbb2/sho...hreadid=342740
Kevin
Kevin
1992 Trans Am
Aug 8, 2015 08:16 PM
