Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
i have a warped super ram lid
Old Jun 8, 2005 | 09:38 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
how do i contact them, i havent seen the issue of gm high peformance
and they are supposed to exchange them
so how do i go about exchangeing it
Old Jun 9, 2005 | 12:54 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
They aren't offering the billet lid exchange anymore. Call the Accel whine line and bitch. You'll probably be on hold for a while........it's a busy line
Old Jun 9, 2005 | 03:11 AM
porkyzilla's Avatar
Engine: 5.7tpi 350,
dont care about a billet one i just want it to be flat
when i lay it down on the plenium there is a gaping gap
and this is retarded and ****ed up
Old Jun 9, 2005 | 06:28 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Might be better off using your lid as a pattern, and having a machine shop cut one out of thicker aluminum. I understand you just want a replacement, but why risk doing the job twice?
-- Joe
Old Jun 9, 2005 | 04:11 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
They'll probably tell you to use silicone.
It may be quicker to have one made
Old Jun 9, 2005 | 04:13 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
And you may want to read this before you slap the SR together.......
https://www.thirdgen.org/techbb2/sho...hreadid=290417
Old Jun 11, 2005 | 12:57 AM
porkyzilla's Avatar
Engine: 5.7tpi 350,
ok some people are telling me that it will straighten out when i bolt it down so i put my hand down on one side and took a picture of the gap is this too excessive
Old Jun 11, 2005 | 01:15 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Pic won't load for me.
I can tell you that you don't want to stress the holes that secure the lid on the plenum any more than you have to. They strip very easily.
Old Jun 11, 2005 | 01:37 AM
porkyzilla's Avatar
Engine: 5.7tpi 350,
ok pic fixed
Old Jun 11, 2005 | 01:47 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
You should be able to get away with just tightening it down. You may want to get some longer bolts for the lid though. The ones that come with the kit don't use many of the threads in the plenum because they're so short.
Old Jun 11, 2005 | 03:25 PM
91Z28-350's Avatar
Re: i have a warped super ram lid
Mr. Gasket, Hurst, ACCEL, Hays, Jacobs, Lakewood and Mallory
Hours: 8:30 a.m. and 5:00 p.m. Mon.-Fri. EST
Phone: 216.688.8300 ext. 500
Address:
Technical Service
Mr. Gasket Company
10601 Memphis Ave. #12
Cleveland, OH 44144
Old Jun 24, 2005 | 09:31 AM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Re: Re: i have a warped super ram lid
They are right around the corner from me, I could go rough them up for you if you wanted me too...
j/k of course.
Address:
Technical Service
Mr. Gasket Company
Cleveland, OH 44144
Old Jun 24, 2005 | 12:25 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I am continually amazed that they sell a Superram setup for over 1200$ and they continue to use shoody lids and bolts that are too short.
I'm no genius, but I think 10 yrs later, they have made all their money back off of tooling, wouldnt u think?
I'm old enought to remember doing them on cars in the mid-90's, had some loaded friends, we had issues on almost everyone that I can think of.
Someone should go beat them in the head profusely.
Another question. After all the times they have screwed someone, from too short bolts to incorrect gasket sets to warped lids and having to argue to get it replaced(after dropping 1200), why the hell do people keep buying them?
later
Jeremy
Old Jun 24, 2005 | 12:34 PM
91Z28-350's Avatar
In CA, you don't have much of a choice. It's the only aftermarket plenum and runner setup with a CARB-EO number. One can stick with just aftermarket runners, but most of us want more higher RPM power.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
no green
Jan 9, 2016 09:22 PM
gord327
Oct 3, 2015 01:25 PM
Dragonsys
Sep 25, 2015 03:51 PM
