Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
SuperRam Performance
Old Jun 23, 2005 | 09:53 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Do you think I'll notice a gain in power by switching to a SuperRam on a stock L98, if so, how much hp?
J
Old Jun 24, 2005 | 10:33 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
yes, 2-3 tenth on a stock L98
I'd do headers and a 3" catback system first
Old Jun 25, 2005 | 01:09 PM
Well I already have the cat back, and I plan on getting headers and a new cat soon.
So headers,catback, superram should be good for a good half a second off i suppose?
Old Jun 25, 2005 | 06:05 PM
Car: 89 Formula 350
yeah, i think that combo would be good for that
Old Jun 25, 2005 | 08:27 PM
That should put me in the very low 14's perhaps high 13's if i get a good 60 ft time with good elevation.
What other bolts ons would help help along with the superram?
Old Jun 25, 2005 | 10:03 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Torque Convertor, Gears, AFPR, Roller Rockers.
Old Jun 26, 2005 | 07:55 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Ditto on what parts GOY suggests.
A SuperRam on a stock L98 is overkill.
Unless you plan to build the motor later, large tube runners, ported base and plenum is the better way to go.
I might one of the few, but I did not like the SuperRam on my 383.
www.geocities.com/dzperf
Old Jun 26, 2005 | 09:49 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: SuperRam Performance
Originally posted by 87TPI350KID.Do you think I'll notice a gain in power by switching to a SuperRam on a stock L98?
Nothing to write home about...
Originally posted by 87TPI350KID.If so, how much hp?
Don't worry about a new exhaust, as true power comes from the valvetrain. Get you're hands on a used, but good, CC306 cam (they're cheap enough nowadays).
I ran that cam with an old L98 that I once had, and the MAF adjusted just fine... although chip work will in fact enhance it's performance, though.
Bump up the fuel pressure, and enjoy what the Super-Ram was really intended for.
Old Jun 26, 2005 | 05:53 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
i have heard that the C306 cam is a beeotch for daily use.. but awesome as a drag use cam..
Old Jul 15, 2005 | 08:38 PM
brutalform's Avatar
Heads, its all in the heads!
Old Jul 16, 2005 | 01:50 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
super ram flows a ton more than the stock TPI so gains will be nice once you add some more fuel from the AFPR.
but like said above, the stock heads dont flow much more than the stock TPI intake, so theres still a restriction
Old Jul 17, 2005 | 12:03 AM
BrandenCali's Avatar
I can go both ways with this question and peoples responses..
One is sure go get a Super ram it will work on a L98.. Your going to gain some tq and hp..
But then question is.. Is it really worth it? It's a bolt on modifaction and you will just need to build around it in the future to really have the full performance of it..
My first Big Mod was a Super Ram.. And it was not just a stock one either.. I gained Alot of power and top end.. I had a catback exhaust and pretty much all the easy free mods and a custom chip also..
So if you feel this is the best bolt on for your car then it would be your choice..
Heads are a thought also.. Heads can still work well with Tpi..
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
