Accel Super Ram setup question....
Car: 87 Trans-AM GTA
I was looking online at the Accel Super ram setup which basically looks like a boxy setup that replaces the stock tpi runners and base. Just wanted to see if anyone has had good luck with it and if there is anything better out there for $850??? for my 87 GTA.
any info much appreciated
thanks!
thanks!
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
I hate to say this but do a
there is tons of info about this intake here and many people have had very good results with it.
FYI i plan on getting one in the near future...
there is tons of info about this intake here and many people have had very good results with it.FYI i plan on getting one in the near future...
thanks for the info,
My major reason for asking is because Ive seen alot of Hype on the board regarding the Holley Ram setup and the Accel seems to be the "older model".
Im basically trying to compare all options.....
thanks again
thanks again
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Its not worth the minimal performance gain for what it cost. Save that money for a cam.
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Sorry, I disagree. I LIKE my SUperRam setup. Plus it's emissions legal, while none of the others (Holley Stealth Ram, etc.) are on our cars....
Don't get me wrong, if I had one, id put it on. I would spend money on other stuff first though.
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
from what ive seen through every result the Super ram is the best performance EFI for our cars out there...i will most definately be purchasing a setup for myself later
where did you find it for 850??? on summit its over 3 grand
Car: 1983 Trans Am (not running)
Car: 1989 GTA
would you need the whole setup for a crate 350....??? i might be able to ask the guy to set it up for EFI but i just want to know what all might be involved. As far as i know itd be a 383 crate motor and i can have it built any way i want...how do i want him to build it so i can put a super ram on it?
Primarily get a cam with a 112 or 114 LSA, nothing less! As for the lifts, that will depend on your rockers/valves/heads/exhaust.
I went with what comp cams tech line recommended for my configuration. You should probably talk to them and a couple of others just to be sure. Other than that, there is no other real "setup" to the engine itself. Just normal stuff (around 10:1 compression max for iron heads, less if gonna add a blower or gas, etc.)
Hope this helps. All I can do is pass on my personal experience here....
Car: 1989 GTA
i was mainly refering to machining the block for the manifold bolts and what not but apparently since its a conversion for any small block chevy i imagine it will go right on top of any crate 383/350
but thx for the info on the cam i plan on eventually going with a twin turbo setup from bbs designs in a few years so my compression will def be btw 8-9:1
Yep, it bolts right up to the standard intake holes on the heads. Mine was even cut for both the early and later (pre-Vortec) heads. Nothing in the block has to be changed at all besides having a decent cam to realize it's potential).
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
