Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Post Your Alternative Port EFI PIX???
Old Nov 1, 2005 | 05:00 PM
  #51
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Originally posted by anesthes
Whose headers are those?
-- Joe
Hooker SuperComp LT's.
Old Nov 20, 2005 | 09:11 PM
  #52
gflo383's Avatar
Car: IROC Z
Engine: 355 MINIram w/boost
my 88 iroc:
my 86 last spring just before it was finished.....
Old Dec 18, 2005 | 05:44 PM
  #53
Camaro_nut's Avatar
This is what the ramjet looks like, if anyone was wondering....
Old Dec 18, 2005 | 06:53 PM
  #54
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
bet it flows great, but i really dislike the look of it.
Old Dec 19, 2005 | 03:21 PM
  #55
Camaro_nut's Avatar
It looks better in person. Still a plain look though. But yeah,
it definitely flows very well. It's actually capable of handling
well over 500hp. I had the throttle body off the intake while
I was swapping the motor in. I looked inside it and there's
defintinely NO restrictions in there! It's all wide open. There's
no need to port it out. I don't think you can even if you'd want
to. Maybe the throttle body hole for a bigger throttle body.
Old Dec 20, 2005 | 01:14 AM
  #56
CAH383's Avatar
Car: 86 Camaro Z28
Engine: 5.3 LM7
Transmission: TH400
Mine before I put it in the car.
Old Dec 20, 2005 | 02:29 PM
  #57
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
11 seconds you can see. But the 300 shot of n2o you can't.
This motor is also for sale.
Old Dec 20, 2005 | 02:46 PM
  #58
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
mines plastic...... *shrug*
edit:
btw, i normally dont have the gay fuel rail covers on it.
the only reason i have this pic is because i wanted to see what it would look like... i took the covers back off.
Attached Thumbnails Post Your Alternative Port EFI PIX???-small_img_0692.jpg
Old Dec 20, 2005 | 04:02 PM
  #59
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
cheater.
Old Dec 20, 2005 | 08:55 PM
  #60
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
This one is from a Mercury Marine Black Scorpion 377.
may not all fit under a stock hood.,But you'll be the only one in town with one. Bolts on to Vortec and FastBurn heads.
tunnel ram style like a Ramjet.
  #61
F-BIRD'88's Avatar
Attached Thumbnails Post Your Alternative Port EFI PIX???-scorpion-intake2nn.jpg
Old Dec 20, 2005 | 09:02 PM
  #62
F-BIRD'88's Avatar
last one
Old Dec 20, 2005 | 09:04 PM
  #63
ZZ4 86 Z28's Avatar
what the crap.
Old Dec 20, 2005 | 10:37 PM
  #64
brutalform's Avatar
From several light years away!!!!
Old Dec 21, 2005 | 09:38 AM
  #65
MrDude_1's Avatar
Car: 91 Camaro Vert
Originally posted by Free Bird
cheater.
Originally posted by F-BIRD'88
last one
on a older show car, i could see that looking fine...
but off the car ( or in a 3rdgen) it looks like the starship enterprise... lol.
Old Dec 21, 2005 | 04:37 PM
  #66
406TPI's Avatar
Car: 1985 IROC-Z
last one
Now that's thinking outside the box! Like MrDude_1 said...it could look pretty sweet on the right car.
Old Jan 2, 2006 | 09:47 PM
  #67
HarryG's Avatar
Cast iron?
Where's the throttle body mount?
Any more pics?
Thanks!
Harry
Old Jan 7, 2006 | 06:21 PM
  #68
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
Originally posted by MrDude_1
but off the car ( or in a 3rdgen) it looks like the starship enterprise... lol. [/B]
some one tell captain picard's camaro (sp, i think that is his user name) about this intake, lol
thanks
Old Feb 6, 2006 | 10:28 PM
  #69
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
Just waiting for the K-member to show up to stuff it in the car now.
Old Mar 5, 2006 | 10:16 PM
  #70
@ZZKKER's Avatar
still a work in progress, still need to finish routeing the wires, and installing misc. stuff. i will post more when finsihed. It is a 355 with converted LT1 intake, world products sportsman 2 heads, has to add material around the water jackets to cover them due to the sportman 2's having slightly raised water ports.
thanks
anthony
Attached Thumbnails Post Your Alternative Port EFI PIX???-thermostat-housing-small.jpg
Old Mar 6, 2006 | 03:17 AM
  #71
83 Crossfire TA's Avatar
huh, what thermostat housing is that, possibly a mid 70's chevy housing?
Old Mar 9, 2006 | 11:53 AM
  #72
@ZZKKER's Avatar
looks like an older Mr Gasket housing, maybee an offenhouser.
What the heck is up with our avitars by the way?
thanks
Old Mar 11, 2006 | 12:21 PM
  #73
brutalform's Avatar
Another pic with new CAI.
Old Mar 11, 2006 | 05:53 PM
  #74
gixxer92's Avatar
Engine: 7.0L, 6.2L
It's just a standard Mr. Gasket housing with O-Ring. Since I'm not using the regular serpintine set-up I can run the radiator hose straight off without hitting the belt amd still clear the mini-ram.
Old Mar 13, 2006 | 05:58 PM
  #75
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
last one
that prob looks really bad *** when you rev, gota love a shaker hood
Old Mar 13, 2006 | 06:18 PM
  #76
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
thanks
anthony
We will have to see if I can get mine done and drivable before you Anthony. I just finished taking the old engine out and will put the new one in in the morning. Hopefully it will start up no problem. I will post pics of the single plane efi, but I guess you could always come over and look.
Old Mar 20, 2006 | 10:34 PM
  #77
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Old Mar 25, 2006 | 07:11 AM
  #78
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
A pic of my 406.
Old Apr 29, 2006 | 07:09 PM
  #79
GTAmazing's Avatar
This is my conversion project not installed yet but hopefully it will be shortly.
Old Apr 29, 2006 | 08:48 PM
  #80
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Most current....
<img src="http://members.cisdi.com/~anesthes/forsale/16.JPG">
Old Apr 30, 2006 | 07:09 AM
  #81
406TPI's Avatar
Car: 1985 IROC-Z
That's nice, did you weld that up yourself? Very nice work!
Old Apr 30, 2006 | 04:53 PM
  #82
GTAmazing, any pics of that setup from other angles? What is the T going upwards on the fule rail for?
Old Apr 30, 2006 | 05:02 PM
  #83
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
The tee looks like the fuel feed line.
BTW, nice looking setup. What did it start out as?
Old May 1, 2006 | 05:21 AM
  #84
GTAmazing's Avatar
It started out as a Wieand Team G not really sure of the age though. I had the top, fuel rail stands, and injector bungs done by Canadian Custom Fabrications. They are a solid bunch of guys who do great work. The fuel feeds from the drivers side the t-fitting going to go to a isolator for a fuel pressure gauge.
Attached Thumbnails Post Your Alternative Port EFI PIX???-img_1995.jpg   Post Your Alternative Port EFI PIX???-img_1996.jpg
Old May 1, 2006 | 05:44 PM
  #85
@ZZKKER's Avatar
that setup is bad ***. what size tb do you have on their? i bet that would benefit the all mighty monoblade from as&m.
what is the long block that assembly is going on? Also, what engine management are you going to use?
Old May 1, 2006 | 08:35 PM
  #86
GTAmazing's Avatar
I want to get a new throttle body at some point...I'm waiting til I find one for a good deal some place. it's going on a longblock with a stock rebuild and older aluminun vette heads (not the d-port). I do have a cam to put in the engine a gmpp zz1 cam with 235/235@.050. but I don't really know what to do for a computer something cheap and easy to use would be my first choice. If anyone else has used that cam some ecm help would be great.
Old May 1, 2006 | 09:53 PM
  #87
Phatfiddler's Avatar
Dont forget to check the lint trap!
Old May 2, 2006 | 05:17 AM
  #88
GTAmazing's Avatar
yeah sorry it was on top of my dryer and I always forget the lint trap...so I wrote my self a little memo...it works well
Old May 15, 2006 | 02:28 AM
  #89
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Finally I can throw a pic in here!
Old May 15, 2006 | 01:16 PM
  #90
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Old Jul 3, 2006 | 12:30 PM
  #91
JayBoCC2's Avatar
Car: '88 trans am GTA
Engine: 5.7L 355 TPI L98
Axle/Gears: eaton posi 3.73 gears
that has got to be the cleanest engine bay on a 3rd gen i have ver seen, and it looks exremely nice... clean... not cluttered.
Old Jul 3, 2006 | 06:33 PM
  #92
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Here is one of my work in progress.
Old Jul 3, 2006 | 07:05 PM
  #93
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Thanks a lot! There was a ton of work into that bay and a lot of little things that don't jump out at you. Too bad the motors a piece...
Old Jul 4, 2006 | 07:58 PM
  #94
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
Old Jul 5, 2006 | 08:41 AM
  #95
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Cam-aro,
Did you tweak or modify the strut tower brace to fit over the HSR intake? How much work was it?
Old Jul 5, 2006 | 12:03 PM
  #96
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Ditto.
Old Jul 5, 2006 | 01:17 PM
  #97
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Pink run is my latest. I just graphed my progress from when it started as a 305 peanut tpi, to what it is now (sig).
Haven't dynoed with the T56 yet, but I never broke axles at the track with the automatic heh.
Old Jul 9, 2006 | 02:22 AM
  #98
Cam-aro's Avatar
Car: '91 Z28
Originally Posted by GregWestphal
Cam-aro,
No Sir. From time to time, I do get vibrations through the hood from the HSR and brace rubbing one another. All I can do is attempt to set the brace the lowest as possible, against the intake, but there is vibrations... generally when I'm setting at an idle. When actually moving, I don't think I ever get vibrations.
Old Jul 9, 2006 | 11:18 AM
  #99
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Current setup. Need a longer rubber boot for the throttle body though.
Attached Thumbnails Post Your Alternative Port EFI PIX???-side1.jpg   Post Your Alternative Port EFI PIX???-side2.jpg   Post Your Alternative Port EFI PIX???-top1.jpg
Old Jul 10, 2006 | 03:57 PM
  #100
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Here's my current set up (as of Saturday 7/8/06)
Attached Thumbnails Post Your Alternative Port EFI PIX???-nttga7-8-06verns069.jpg
