Post Your Alternative Port EFI PIX???
Car: 88 iroc vert
just wanna see what type of EFI you guys have, head/cam combos and power ratings.
could you please post some info/pix?
Thanx
Mike
Thanx
Mike
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
396 RWHP at 6250 RPM, 385 ft.lb at 4200 RPM
Minirammed 385 with 10.6:1 compression, AFR195 heads, hydraulic roller cam, Accel DFI gen 6. Currently converting to FAST LSX EFI computer in speed density, bank-bank configuration.
Originally posted by cali92RS
One word...
Colorful
One word...
Colorful
It also can idle in Woodward Dream Cruise traffic for four hours straight, never exceed 186 degrees, then immediately lay down 396 rear wheel horsepower on the Livernois chassis Dyno.
I'm hoping for an even better performance at the tenth annual Michigan event this upcoming october 10th where I should see the engine hit 400 ft.lbs and tip it over 400 RWHP with a better tune and the FAST LSX ECM that I have here in the box. If I can find traction I might even tickle some 11-second time slips out of the engine.
Notice the Edelbrock TES6872 headers? Dont anyone ever tell you that they are junk. I've got some Hooker long tubes hanging up to go in over the winter but for now, the Edelbrocks seem to be doing a fine job with exhausting this engine. It doesnt start dropping power until after 6250 RPM.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Yes they are. You can run them so they are not that noticable I have one of the lines running from my radiator to my heater core. It runs along the frame rail
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
is that the ramjet?
no stealth ram...i milled the top ribs off becuase i was bored in machine shop, and spent endless hours polishing..it turned out pretty good, but NOT WORTH MY TIME, definately wouldn't do it again...
well, i think it looks good, and unique.
i had a question about that...you don't leave your throttle body open to the air like that normally, do you? sometimes i see pictures of stealthrams and they leave the opening to the throttle body wide open. isnt that like bad...or do they just do it for the pictures
thats before I had everything put together...if you look, i don't even have the raditor cover on in that picture, and i didn't even have the airbox in either. So to answer your question, no I dont' ride around like that, I have MAF, so I need that tube on there too...also that TB was 500 bucks so I had to show it off a little bit
and yes that is bad, your suckin unfiltered air into the motor, never a good idea..
and yes that is bad, your suckin unfiltered air into the motor, never a good idea.. Member
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
You Bastard! I thought I was the first and only to mill down the top! I'm going to have a buddy engrave something on the top of mine, then finish polishing it. Great minds think alike
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
here is a pic of my. don't know any power ratings yet but i'm also hurting my power output with the small headers and some other little stuff. after 9000 on the motor and accessories i was alittle hurt for money. sig has run time in the 1/8
Engine: 4++,350 & 305 CIs
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Car: 1992 Camaro RS
no sorry just a fuel pressure gauge. the AFPR is on the fuel rail. if you look closely you can see it in the rear
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Just out of curiosity. Why do people run just an air filter on the end of the throtle body? Is it just for the look? You would think that the stock one might be better cause your not pulling hot under hood air.
Car: 1992 Camaro RS
well for me i didn't have a TPI i had a 305 TBI then a 350 w/ a 454tbi then the stealth ram. i'm going to do a CAI as soon as i get some money and time. I'm in Japan right now. working on my Skyline
Car: 92 Z28
Engine: Boosted LSX
Nice pic's everyone.
There are a FEW of the HSRs milled down like that. Jmatlock did his long time ago.
I did this one for a guy I know back in '04
http://www.cecoatings.com/images/Car...SRandTurbo.jpg
yea TPI383 is who gave me the idea....well actualy I tryed just polishing the top of the ribs....then painting the whole top, then trying to just wipe off the top of the ribs...well it didn't work...so i had a HSR that had a red top on it...so i desided to just mill the whole deal off..
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Not too alternative besides the custom machine work, but it is for sale if anyone's interested
how much are you looking for for that?
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
406TPI,
What is that aluminum box type thing that the coolant hoses go into. Is it just for looks?
Car: 1985 IROC-Z
Originally posted by 89 Iroc Z
406TPI,
406TPI,
Originally posted by TPl383
Love the yellow MINIRAM!!
It was a five step process to powdercoat it.
1) Polish it like crazy
2) Mask off what you dont want powdercoated
3) Powdercoat what you do want powdercoated
4) heat cure carefully
5) re-polish out the parts covered with mask, because the yellow will indeed find its way around the mask.
It took me about sixteen to twenty hours of work to get it that way.
BTW, the torquey engine is now F.A.S.T. XFI powered and all my flat spots went away. Mash the gas and it buzzes like an angry bee. First gear is waste-the-tires, second gear is crazy-fast, and third-gear is arrest-me-fast. Fourth is stupid-fast, fifth is blow-the-hood-off fast, and sixth, well, lets just say I've never been to sixth gear except when cruising.
It turned 396 RWHP at Livernois dyno in late august and I'm sure it's now over 400. In fact, my rear axle is now skiving off steel from somewhere and it's beginning to howl... I thought I bulletproofed it, too! I guess the Richmond gear folks were right...
Car: 92 Z28
Engine: Boosted LSX
I guess you didnt see my sig...lol. I own CE COATINGS Ive coated a few MRs
Looks great.
http://www.cecoatings.com/images/coa...iram/Engine%20(1).jpg
http://www.cecoatings.com/images/coa...MiniRamRed.jpg
http://www.cecoatings.com/images/coa...RamRedLogo.jpg
Befor polishing
http://www.cecoatings.com/images/coa...almostDone.jpg
Looks great.
Befor polishing
[B]I guess you didnt see my sig...lol. I own CE COATINGS Ive coated a few MRs
Looks great.
Looks great.
However, now the work is tapering off again so I need to find something else. Hence the F.A.S.T. gig. Unfortunately that isnt paying any bills yet, but I did end up with a nifty new ECM in my car for R&D purposes...
Just curious: WHich powdercoating system is your principal piece? Are you still using Hotcoat or have you moved into Tiger Drylac powders and a commercial gun for doing your pc work?
...and with regards to ceramic thermal barrier coatings, are you using the Technline coatings series? I did my own pistons in Techline CBC2 but after a summer's worth of engine use, I haven't popped off a cylinder head to see if its still there or not.
PM me if you dont want to answer on this thread as this is probably bordering on thread hijack.
Car: 92 Z28
Engine: Boosted LSX
I only use Hotcoats Chrome powder a few times. I have a nordson setup. and use TCi and Tyger powders and many others.
Get on AIM so the thread can stay on topic.
Car: 1986 Camaro z28
Engine: 305 tpi/light mods
Transmission: 700r4/ B&M mega shifter
Just curious are these your daily drivers, i would love to do some gutting under my hood emmisions, ac, etc.. would you recommend this for someone who drives their thirdgen everyday, or does it even makea difference?
Car: 92 Z28
Engine: Boosted LSX
If you answer No to all of the above gut it.
If anything id keep the heat and swap to a non ac heater box.
Im actually puting heat back in my vert since Im in ohio.,
Cool, actually I dont have the ac anymore and there are (expensive)ways of getting around emmision standards
I think ill keep the heat too but other wise ill go for it thanx, oh one more thing kinda off the topic dumb question I have a turbo hood fully vented, I live in nyc and its gonna be getting very cold soon do you guys fore see me having any problems engine wise besides the car taking forever to warm up and getting a little wet under the hood every now and then.?
I think ill keep the heat too but other wise ill go for it thanx, oh one more thing kinda off the topic dumb question I have a turbo hood fully vented, I live in nyc and its gonna be getting very cold soon do you guys fore see me having any problems engine wise besides the car taking forever to warm up and getting a little wet under the hood every now and then.? Last edited by z28 NyC; Oct 4, 2005 at 09:30 PM.
and related to his question, what are the advantages of removing the padding from under the hood. cold winter is coming up here too. thanks.
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
The paint only made it 21 years before I had to have it redone.
Just don't make paint like they used to!
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Current set-up is an accel pro-ram. With a cutler (now holley) single plane efi, home ported sportsman 200cc heads, and comp hydraulic roller (230/236 .544"/.555") it put down 350hp/348trq through a tremec TKO and a 9". Current setup..???
436 SBC, 11.2 C/R, Brodix Track1s, Comp solid roller. The SuperRam is unported as far as the runners go, but the intake ports were modified to fit the large ports on the Track1s. Now it has a homemade 4" CAI, that has a large K&N filter before the pass. front tire.
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
this is my 355... trickflow heads and a comp cams mag292 cam... stock tune put down 279 hp at the rear and 303 lbs or torque
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
