Thinking of converting to a single plane/solid roller.
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Just wondering what my options where, and if there would be a justified difference in power. I don't care about streetability, or maintenance, I want HP.
Currently I'm running a HSR, cc306, and Protopline 200cc heads on a 350. It put down 355/350 rw power and I was curious to see if the swap would be worth it. Any thoughts?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Thinking of converting to a single plane/solid roller.
ACCEL's pro-ram is also a decent intake. Kenwood is using one on his car.
I'd stay away from the victor efi. It seems like the cheaper, crappier of the singleplane intakes.
-- Joe
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
If you measure runner length and width or the volume, you will find that they are similar to the HSR or minirams floating around. So your answer lies in what a HSR or miniram act like.
I am still working on my single plane conversion. I have made three different throttle bodies for the intake before I arrived at the one I liked. I am not going to say anything else on it before I finish it though. I am writing up on it. It looks pretty though.
Re: Re: Thinking of converting to a single plane/solid roller.
-- Joe
-- Joe
The victor is simply a Victor Jr with injector bosses I thought.
Which would mean that the VJ is a cheaper crappier intake too.
Which a lot of people would disagree with.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Re: Re: Thinking of converting to a single plane/solid roller.
Originally posted by Z69
I'm curious as to what you base this on. NO baiting...honest
" Victor EFI is based on the Victor E manifold #2978. Ideal for high-rpm drag race applications, the Victor E has a larger and deeper plenum than the Victor Jr. #2975. It provides maximum power in the higher rpm range for engines with standard port location iron and aluminum heads. Runners have a tapered cross-section, and plenty of material at the manifold port exit allows port matching to many different heads."
The way the fuel rails are held down is kinda shabby. I don't like it at all.
The port size is small, and cannot from what I understand be ported much larger than a 1205. Edelbrock claims it can be port matched to bigger heads, but everyone I've talked to that has one says there is not enough material to port it.
But of course, this is all just my opinion. When I did my research, I went with the Holley because it appeared to be the better of the manifolds. But thats just me.
-- Joe
Engine: 355
Axle/Gears: 4.11
Car: 1991 Z28 Vert
So there won't be much difference between the HSR and a single plane EFI?
1992 Trans Am
May 10, 2023 07:19 PM
