Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Question for HSR users
Old Sep 6, 2005 | 03:19 PM
Camaroz29's Avatar
Any of you notice a slight amount of gasoline coating on the lower manifold? There isn't any leakage or pressure loss, I just was wondering why I always smelled gas so strong and upon close inspection noticed a slight coating of gas around my HSR. I'm thinking this is normal though, hopefully some of you guys can chime in.
Old Sep 6, 2005 | 08:45 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Mine's as clean as when I installed it. No gas at all.
Old Sep 8, 2005 | 12:23 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Where are you seeing the gas on the manifold? I noticed some around the FPR and one of the bolts was loose.
Old Sep 8, 2005 | 08:39 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You should never have fuel in the engine bay, anywhere.....
You have a fuel leak, that can be very dangerous, find it and fix it.
Old Sep 8, 2005 | 11:09 PM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 3.73
Do you have the Holley AFPR that came with the rails? If so, that is more than likely your problem. They are known to have problems with holding pressure and would leak a small amount of gas. If that is not the problem, check your fuel line fittings and make sure that the fuel rail fittings are not leaking as well.
Old Sep 9, 2005 | 06:47 AM
Camaroz29's Avatar
It is back by the AFPR, even though I can't detect a leak. I'm going to tighten everything up though just to make sure.
Old Sep 9, 2005 | 08:12 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Better recheck mine
1992rs/ss
16
Jan 28, 2016 09:58 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
ASE doc
Aug 25, 2015 09:14 AM
355tpipickup
Aug 22, 2015 06:06 PM
redmaroz
Aug 16, 2015 11:40 PM
