Fuel gauge for HSR
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Fuel gauge for HSR
What fuel gauge are you guys running with teh HSR system on the valve to the left of the throttle body. Thanks.
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Any one have the part numbers for them. Want to do one so I don't have to keep putting the checker on there. Any tips to this too? I do like the autometer gauges personally the Ultra-lite edition. Do they make one that is liquid fuild, I couldn't find one on Summit's website. Thanks.
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
I dont know about the liquid filled but the autometer install kit has all the fittings youll need and hose i mounted mine on the passenger fender well
Transmission: A4
Accel sells a fuelpressure gauge that mounts directly to the schrader valve on the fuel rail on TPI cars. I had one lying around and used it on my HSR. it is mounted on the RH rail at the front near the TB. IIRC< Ihad to get a few different fittings to get it to work. The gauge will come with a 90 degree hard line to mount it in place. Below is the pic of it. I think it is about 1 1/2" diameter.
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
I have one attached to my SX adj/regulator like BOTTLEDZr28
described. It was about $30 but mine goes to 100psi.
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
id defenitly like to know what other fittings would be needed to get it to mount on the fuel rail too..
as far as the gauge is concerned
http://store.summitracing.com/defaul...=egnsearch.asp
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Thanks...is that Accel one liquid filled as well. I really don't want a 2 5/8 gauge sitting right there...1 1/2 will do me just fine.
Car: 1991 Z28
Engine: 383
now that i think about it i dont either. 1 1/2 inches would be fine...are there any other fuel press gauges that are small AND liquid filled?? i cant seem to find any besides the bigger autometer and that accel you pointed out
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I found a Summit Racing gauge that is liquid filled and 1 1/2" for like $20. Looks nice just has Summit on the face of it and a Chrome ring. I think I might get that one...the Accel one is not liquid filled. Just found that out.
Car: 89 Formula
Engine: 355
Ghettobird52
Jul 5, 2024 11:18 PM
R3500
Aug 17, 2015 12:16 PM
