Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
does this make sense?
Old Oct 18, 2005 | 03:52 PM
1989iroczaz's Avatar
Car: 1989 camaro iroc-z
I was thinking about upgrading my stock TPI intake to either a holley stealth ram or an lt1 intake .For 2 reasons one too make more power obviously.
And two is the one i'm asking about.I'm trying to save the stock 150,000 mile rear end, for as long as possible and since the Tpi intake is such a low end torque monster,Would the change to an HSR or LT1 intake be less hurtfull to the rear end since they would move the power band up and reduce the amount of low end torque.
Any replies will be appreciated.
Old Oct 18, 2005 | 07:06 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
When you are trying to save it right now and you are concerned about it, chances are it will break. Yo said yourself that you are wanting to make more power, that can break a rear end, especially a 10 bolt. Go to a junkyard and dig out a 9 or 12 bolt and slap some gears in it and call it a day. Or dig out a 10 bolt and put a couple $100 into it. The 10 bolt can take punishment, but only so much. Many people on here running LS1's and fast traditional sbc's naturally aspirated are reporting breaking them.
Old Oct 18, 2005 | 08:24 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
The HSR makes more HP with some loss of torque, but I still tore up a b/w 9 bolt with it at a drag strip. If you are going to make more power you will need a rear end that will handle it. I would recomend the HSR over the LT1. I know guys who gained nothing with the LT1 on the L98.
Old Oct 19, 2005 | 01:50 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Did you have drag slicks, street slicks or street tires on the car?
Old Oct 19, 2005 | 06:29 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
Street tires, the ones in my sig. I had the pressure down to 16 psi
RazorN8
Jan 7, 2022 11:44 AM
onefreakz
May 14, 2018 12:15 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
86IROC112
Aug 17, 2015 07:57 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
