Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
TPI to HSR swap...lets see some engine bays
Old Jan 27, 2006 | 01:51 AM
  #51
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Old picture, but brighter.
Most recent pictures. I have since done some more wiring tucks.
Old Jan 27, 2006 | 09:25 AM
  #52
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i remember seeing your motor mocked up a LONG time ago when you made a thread about it and at that time i didnt know really anything about the HSR...so i guess i can say your mocked up motor was one of the contributing factors in me going with the stealthram!
looks good
Old Jan 27, 2006 | 12:53 PM
  #53
looks good
Awww now I feel like Shakespear for inspiration or something
Old Jan 27, 2006 | 03:38 PM
  #54
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Hey what are thoes radiator hoses fit for I'm using one of thoes dumbass bendie straw hoses and hate it any help or P/N would be appreciated
Old Feb 1, 2006 | 10:31 PM
  #55
irocz43's Avatar
here is mine nice and neat.....
Attached Thumbnails TPI to HSR swap...lets see some engine bays-enginesmall.jpg
Old Feb 2, 2006 | 10:37 AM
  #56
CAMAROJOKESTER's Avatar
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
I KNOW THIS IS A LITTLE OFF OF THE TOPIC, BUT I HAVENT INSTALLED MY HSR YET, AND SOME GUY TOLD ME THAT I WOULD NEED A DIFFERNT A/C BRACKET IF I RUN SERPINTINE.. IS THAT TRUE.. THANKS..
Old Feb 2, 2006 | 10:53 AM
  #57
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
he is wrong.
Old Feb 8, 2006 | 01:15 PM
  #58
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Hey, Twilight - what's that switch on the passenger strut tower next to the overflow jug? Is that just a battery disconenct or something else? Just curious... nice looking set up by the way!!!
Old Feb 8, 2006 | 01:49 PM
  #59
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
yea...im wondering too. i need a distro block for the engine bay and need some ideas on whee to get one and where to put it.
well, i started the thread and i finally have something to post. its not done but you get the idea
Old Feb 8, 2006 | 03:12 PM
  #60
Summit sells distro blocks and such. Do some searches and you'll find out about em.
What I've got is a circuit breaker for my amplifiers in the back. Breakers are so much nicer than fuses!
Old Feb 8, 2006 | 03:48 PM
  #61
vernw's Avatar
OK, thanks for the reply. Just didn't know what that was and was curious. No big deal.
Old Feb 11, 2006 | 03:26 AM
  #62
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Heres mine,soon to come in the car.
Attached Thumbnails TPI to HSR swap...lets see some engine bays-cattas-fest-och-motorn
Old Feb 11, 2006 | 11:02 AM
  #63
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
looks good. i like the valve covers, ive seen them before somewhere...
Old Feb 11, 2006 | 11:11 AM
  #64
Engine: 383 HSR TPI
Axle/Gears: 4.10
Yea!
They have pre owner in the california US,its a small country but now they will performe on the Swedish streets for sure.
Old Feb 12, 2006 | 08:18 PM
  #65
Abubaca's Avatar
Johnny Blaze, is it me or did you run your fuel lines in parrallel instead of in series?
You guys scroll back up top and check it out. He's got that big ole aeromotive fuel reg. in there too.
I've heard of doing this for very high fuel flow rates. Anyone care to chime in and tell me a little more? Johnny?
Old Feb 13, 2006 | 07:08 PM
  #66
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Almost ready
The before shot is in the sig or on my site, New buildup is just about ready to go in.
Gotta go out of the country again so its setback time for a week or two. Gotta get this done by spring or I'm going to really be upset with myself.
Guess I don't feel so bad, everyone seems to be half done right now
Attached Thumbnails TPI to HSR swap...lets see some engine bays-mockup01.jpg
Old Feb 13, 2006 | 08:28 PM
  #67
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
looks very good! yea, dont feel bad this project was supposed to be done well over a year ago
Old Feb 13, 2006 | 09:20 PM
  #68
JP86SS's Avatar
Thanks, I wish I could take mine to that level and start clean.
It will be worth it in the end. I'm still scrubbing gunk off the engine compartment, frame, etc. and painting as I go.
Starting clean lets you do everything right. Takes allot more time messing with all of the little things though.
To do mine any cleaner it would be ALL in pieces and take years at the rate I get things done. I'm picky about doing it once and not having to worry about something later. Good luck with it, should be real sweet when its finished.
Old Feb 13, 2006 | 09:23 PM
  #69
JP86SS's Avatar
I think having them in parallel would decrease any chance of pressure drop in the rails when the injectors fire. Double the path, 1/2 the resistance with the reg at the end of both rails.
Should work well if the supply line is larger than 3/8 (-6). Any smaller and the pressure drop in the supply line may negate the benefit.
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
