TPI to HSR swap...lets see some engine bays
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
alright i need some pics of good looking non cluttered engine bays (any tpi type motors) to give me some ideas on where to run all my wires and hoses when i get this new motor in. i need some visual help on what to do to make the bay look clean and simple
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
ya but after 9000 into the motor i sort of didn't have the money left. i have it in the plans though. along with bigger headers and a th350 trans
Car: 1991 Z28
Engine: 383
looks good guys, keep um comin! does anyone have any tips/suggestions for making the engine compartment with a stealthram less cluttered??
fire...i see you are running 8.4X and trapping 80...i cant get out of the 9's and am trapping 81
Car: 1992 Camaro RS
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally posted by firedawg225
all depends on the track. long 1/8 short 1/8. some track are true 1/8's. the track i was racing at is almost a true 1/8. I know another thing which i tought was pretty cool. I would race people and there times would be close to mine but there MPH were 10 lower then mine. I would lose some of my races at the start and win at the end. all i care about is the big W. hehe oh well
Last season on my old 355 setup, I could run 119mph every pass, and any e/t from 12.40 to 13.80 all at 119mph. It was just how I came outta the hole that mattered.
-- Joe
Car: 1992 Camaro RS
True true but my times have nothing to do with that. true i have some suspension work but my tires suck kumho 711. not the greatest i still spin um off the line even with a good burnout.
Car: 1991 Z28
Engine: 383
man i cant wait to get my motor in!!
whats everyone doing for their injector plugs? are you using the stock wiring harness or something else? i noticed free birds looks different than mine...
Car: F350
Engine: Powerstrokin
Although I have a different application, you can do the same. I turned the injectors so the connector would face the center of the engine. This hides the wiring.
Car: 1991 Z28
Engine: 383
thanks for the idea FIERO. thats what im talking about, that looks sweet.
does that make it difficult to install/remove the injector plugs???
Car: 1992 Camaro RS
i'm using the C950 computer from holley. bought the hole it. makes it very easy to change the computer. you can watch and change thing in realy time.
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Here's mine. I also used the C950 w/harness, getting rid of the factory harness will clean it up a LOT.
Car: 1991 Z28
Engine: 383
i have a couple breathers to help woth pressure build-up and dont enjoy what the pcv leaves behind in my intake manifold
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Cam &heads for the HSR
Hi!
Can i ask you all what heads and cam are you running whith?
I cant decide if the ZZ4 or the ZZ4 hot cam will be the best for me and what heads for that combo.I will install the HSR this winter and dont wont to make any misstakes this time.
And do any know vere to by a fuellinekit to the HSR?
Thanks!
Thanks!
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Re: Cam &heads for the HSR
Originally posted by Firebird sweden
Hi!
Thanks!
Hi!
Thanks!
Car: 1991 Z28
Engine: 383
as far as the fuel lines are concerned...cant really buy a kit, gotta make one. see www.stealthram.com for more.
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Here's mine:
I'm running a Commander 950 system and harness as well. My car originally had a CC Quadrajet, then was just plain old carb'd, and now it's fuel injected
I still need to neaten things up a bit, but it's not too bad. Now if only I could get it running right
-Paul
-Paul
nothing special, nor complete..
I drove the car for a week and cracked the block
... Never did take pictures of the engine in working trim..
It did move the car nicely though..
ps. gotta update my sig
... Never did take pictures of the engine in working trim..It did move the car nicely though..
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Dont know about more power, first reason to swap was the PITA SR install.......
The big diffrence was in the procharger swap from 600b to F1
/N.
/N.
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
wheels are www.imagewheels.co.uk
style L5
style L5
