Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
TBI to multiport...
Old Nov 20, 2005 | 08:52 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
TBI to multiport...
Hopefully this doesn't get deleted immediately... I realize this isn't completely 3rdgen related.
I have an 89 s10 blazer with the tbi 4.3. I'm doing a solid axle swap and will be wheeling this truck a lot, quite a bit at odd angles. I'm interested on the ideas of some of the guys here.
How hard would it be to pull the tbi unit off, tap injector bungs into a stock or aftermarket carb manifold and run a multiport setup on the 4.3? What computer should I run? What computer does it have stock? Couldn't a late model chev truck vortec TB be adapted because of the built in tps, iac and map sensors?
Old Nov 22, 2005 | 12:28 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
You might try this article here... The '89 Blazer 4.3 uses a '7747 ecm doesn't it??
Repinning TBI to Speed Density TPI
Old Nov 22, 2005 | 01:30 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Thanks!
I'm not sure what ecm it is yet. It looks like it's a sealed unit mounted in the engine bay but I could be wrong and that could be something else, it did look a little small...
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
