Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
what size throttle body for setup
Old Dec 12, 2005 | 07:56 AM
ml258-89iroc's Avatar
Car: 1989 iroc
Axle/Gears: 2.77
I recently ordered a vortec stealth ram and scroggins dickey vortec heads. I plan on using a lt4 hotcam and i also have 22# bosch injectors(I think they are pink) I was leaning towards a 52mm tb. does this combo sound right? thanks
Old Dec 12, 2005 | 08:35 AM
Evil 88IROCZ's Avatar
Car: 88 IROC
Engine: 305 tpi
Transmission: 5 speed
52mm I like Holley however BBK has a decent one. Don't get the 1000cfm like most people think is nessary it will give you soggy response and loose power down low with no gain up top.
Old Dec 12, 2005 | 12:23 PM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
I definitely wouldnt go bigger than a 52mm on a 350. The 52mm should be perfect.
Old Dec 12, 2005 | 02:56 PM
Car: 1989 iroc
Axle/Gears: 2.77
thats what i was thinking. thanks for the input
Old Dec 12, 2005 | 07:50 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
A 22 pound injector equates to fuel delivery appropriate to approximately 350 crankshaft horsepower or, about 300 RWHP.
With 300 RWHP, you'll not need anything greater than 52mm. The HOT cam and those heads should get you in the neighborhood of that kind of power. Sounds like a pretty well balanced combo. Just dont go too big on header port size. 1 5/8 primaries will help optimize your torque and horsepower. People knock them I know, but I've had good luck with the Edelbrock 6872 TES header & Y-pipe. I've pushed 400 RWHP through them with my 385 and peaked at 6250 RPM. So they cannot flow all THAT bad... Plus they are inexpensive.
Old Dec 16, 2005 | 08:20 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Does anyone have any hard numbers to support the theories on TB sizes?
Old Dec 16, 2005 | 08:27 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
On my 383, I saw an increase in low end tq and upper end hp. So, can't say I agree with you. My tq down low is more noticeable b/c its in a truck and every bit of tq I pick up is noticed.
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
Street Lethal
Apr 30, 2019 12:14 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
