fuel rails for vortec stealth ram
Car: 87iroc
Engine: 5.7vortecstealthram
Transmission: 5-speed
Axle/Gears: 9-bolt posi
just wondering whats the difference in the fuel rails between vortec application and regular. I know the adjustable is a little more expensive and should aid in future mods tuning.
I don't know but I have wondered, too.
My guess is that the Vortec might have altered locations for
the injectors. Hence the rails would be drilled differently.
Another thought is how the cross-over tube is shaped to fit
in the area between the runners and the passage to the
t-stat.
Rail mounting points? ect ...
The cross-over tube would not be a big issue preventing
someone from using a common rail set but the other aspects
would create some trouble.
t-stat.
Car: 87iroc
what about the fuel lines, go with the rubber hose for barb fitting or the braided hose with the an fittings
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
I would definatly do braided hose rubber and barbs on fuel injection just doesent sit well with me theres a good amount of pressure in the system and I would want the smallest chance of fire possible
Car: 87iroc
ya I guess I'll get some good braided stuff then whenever the rails get in and the adapter fittings to connect to the hardlines alrighty then thanx alot, oh ya how does your tranny handle the increase power
Car: 89 Formula
Seems to do ok but I only have one season on it really and havent used any stickies but I plam on blowing it up this season with my new motor
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
I'm replacing a regular Stealth Ram with a Vortec version. I'll try to find the differences and let you guys know and/or post pictures.
-Dave
-Dave
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Ok.
I'm heavy into getting a StealthRam, but wondering about the fuel rails itself.
Is the fuel rail different from the standard Slthram?
I havent found a different part number for the vortec version(which I need). Someone happen to have the vortec fuel rail part number?
later
Jeremy
later
Jeremy
Engine: 383, 327
Vortec Stealth Ram Fuel rails w/ non-adjustable regulator is Holley # 534-192. They are on back-order from Summit. Mine is expected the first full week of March.
I think the one with the adjustable regulator is 534-193. Check Thunder Racing's website, they have it listed there.
-Dave
-Dave
Car: 87iroc
After viewing some pics I think they are revised due to the fact that vortec heads have raised intake ports. So there would be a little clearance issue w/regular fuel rails. My rails are in finally after a four month wait, the engine and tranny are bolted together and just waiting to drop in. Now I just have to worry about the fuel lines, I'd like to buy a kit pre-assembled but can't find anything up here in Canada. Maybe I'll just go to a speed shop and ask them to put together the lines with the AN fittings and adapters to connect to the hardlines. It's been a long time coming from when I blew the 305TPI (late last summer) and can't wait to see what the vortec stealthram will do
Engine: 383, 327
-Dave
-Dave
-Dave
9192camaro
16
Feb 3, 2019 12:21 AM
L98GTA87
Aug 11, 2015 06:55 PM
