Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
accel single plane efi
Old Feb 27, 2006 | 08:11 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
i need to know if i will need to put a cowl hood or a ram air on my 89 ta I am going to a accel single plane intake and a turbo setup it may be a single tb and an elbow oa i may stay with the 4 barrel design havent decided what will be better but i need to know if a larger hood is needed please help car must go to paint in a week
Old Feb 27, 2006 | 09:49 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: accel single plane efi
Awfully demanding!
In my opinion, no. The Accel is a lot taller than the holley/cutler, and mine rubs slightly.
Kenwood I think is running the accel setup. I think if you had a camaro you'd get away with it.
To bad your not local, I have a 2" cowl for sale. heh.
-- Joe
Old Feb 27, 2006 | 10:02 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
ok
that is what i thought thank you for the info though is your car a turbo?
Old Feb 28, 2006 | 06:16 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: ok
No. I'm not a turbo fan.
-- Joe
Old Mar 22, 2006 | 12:22 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Even with a camaro thats pushing it...
I have a turbo and accel pro-ram, PT elbow, etc etc... I have the early style RA1 hood...I have about 1" clearance... the cowl is about 2" Basically with the hood off if you run a straightedge from quarterpanel to quarterpanel the top of the TB would be FLUSH..
So stock hood on a bird wont work... camaro gives you more room But still would be too close for comfort>>>>ALSO even to get the clearance I did you have to mount the TB with the IAC on the DS, your throttle cable on the PS and the TPS Under the arm****Which makes the tps almost rest on the t-stat outlet... Because of that you can mill down the intake or they will interfere>>>unless you use a remote mount t-stat.. Im not saying it CANT be done...because it can.. Im just saying that easily getting it to clear a stock hood will be a challenge... One day I will retool my setup anfd get it under a stock appearing flat hood..
Old Mar 24, 2006 | 12:19 AM
57TUNED's Avatar
Car: 88 iroc
i got my to fit with a 100 degree elbow from wilson but still takes some work
Old Mar 24, 2006 | 09:18 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
I got mine to fit with the cutler setup, a s/c top hat, and an angled spacer. Only problem is when I removed the air intake on the dyno, I jumped from 308 to 347 rwhp (hence the subsequent purchase of a 4" cowl hood). If you want it to fit under the stock hood pick another intake. If you want the benefits of the single plane, buy a new hood.
Old Mar 27, 2006 | 07:08 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Whats your new "hat" look like?
-- Joe
Old Mar 27, 2006 | 08:15 AM
Lo-tec's Avatar
14X3 K&n extreme air filter with a 26" wide cowl pan that seals to the hood.
Fanatic1074
Oct 3, 2022 05:57 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
dusterbd
Sep 29, 2015 08:40 AM
efiguy
Sep 27, 2015 01:30 PM
