Got the HSR CAI mocked up finally!
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
just thought id share a pic or two. i just need to go get it TIG welded and ill more than likely paint it black. opinions/suggestions?
it runs through a hole the custom battery tray i put in with a k&n cone gettin cold air!
Car: 1989 Iroc-Z
Engine: 350ci SBC
Did you install the cooling system before you mocked that up....Seems there wont be enough room...here is mine:
https://www.thirdgen.org/forums/atta...g?d=1123476084
https://www.thirdgen.org/forums/atta...g?d=1123476168
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
both look really nice and clean. question that i have is what did you guys use to install the cai to the TB. i ended up going with the firebird elbow and using a cheap autozone tube and filter. i just put it in for a quick fix with the intention of re doing it.
Car: 1991 Z28
Engine: 383
slow...yea, i had my radiator in while mocking up tings. its close but fits like a glove. if you are referring to the coolant overflow my fenderwells are smoothed.
smoke...all i did was purchase a silicone connector and two tbolt clamps (like you would see on a a turbo system) and ovalized the 4" exhaust pipe to mate with the oval TB.
