Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
superram fuel lines
Old Apr 15, 2006 | 10:34 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
superram fuel lines
Off the top of my head... If i am right, aren't the fuel lines on the superram on the opposite side as TPI are on the fuel rail ?
Old Apr 17, 2006 | 03:23 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Since I re-used my TPI fuel reail, they didn't change. My SR didn't come with fuel rails, don't believe they even offer them....
Old Apr 21, 2006 | 01:27 PM
Poppa Chubby's Avatar
Car: Vert IROC Camaro
Engine: 355ci
Axle/Gears: 9-bolt w/3.45s
Ditto.
I re-used the rails from my TPI.
Old May 29, 2006 | 07:23 PM
primo's Avatar
DO you have any track times for the SR?
Old May 29, 2006 | 09:33 PM
Car: 92'Camaro RS
Engine: a loud one
I don't have any times yet. As a matter of fact i haven't even installed it yet. In the process of polishing it right now. I am not sure when exactly i plan on the install yet cause i still have a lowering kit setting in the basement that needs put on. Too many parts, so little time.
Old May 30, 2006 | 02:45 AM
vernw's Avatar
I should have your problems, David! Poor boy....
I don't have any times yet with my SR either. Been trying to run down a split AFR issue before doing my WOT tuning. Want to make sure I'm not leaning out one side compared to the other (or flooding one out either).
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
