Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Simple HSR question
Old May 25, 2006 | 06:52 PM
MonteMan357's Avatar
Car: 1991 Z28
Engine: 357
Transmission: T-56 waiting to go in!
Axle/Gears: 3.73:1
Simple HSR question
Well i was trying to get the HSr bolted up tonight and ran into the typical problem with my 91-92 throttle linkage not clearing the fuel rail fittings. I did what sdome have said and i flipped the rails around so that the FPR is on tha pass. side front of the engine now and the fuel inlet is on the drievrs front side. I am still haveing a clearance issue, though. My fuel inlet has the straight AN fitting on there and it gets in the way whdn i have my fuel line hooked up. What i need is a 90* fitting that will screw into the female hole in the rail itself to replace the straight fitting. The only problem is i dont know what the thread is inside of the fuel rail itself. anyone know what the thread is on the INSIDE(female part) of the fuel rail on the fuel inlet side?
Old May 27, 2006 | 07:27 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I installed them in the stock manner as directions said to, and just bent my nautilus style throttle bracket out a bit till it cleared the fuel rails. Easiest fix for me and you'd hae to look pretty hard to see its been bent.
Old May 28, 2006 | 07:56 PM
stealthrocz's Avatar
Car: 87iroc
Engine: 5.7vortecstealthram
Transmission: 5-speed
Axle/Gears: 9-bolt posi
I have the same problem and I think I'll try your solution first before I go purchase the new throttle body.
Old May 28, 2006 | 11:56 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I put mine on the stock manner as well but I dremeled some of the material away on the 90* elbow to clear then painted it to match and it looks like it should be there.
Old May 29, 2006 | 12:10 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
I have an 89 TPI.
I did mine with the regulator on drivers rear (requires 180* fitting)
The inlet in on pass rear (requires 90* fitting)
I also had to keep the schrader valve on the Pass side fuel rail and bend the throttle cable slide to clear the fitting on the drivers side.
As far as thread size onthe fuel rails they are standard -6 Male o ring type.
Old May 29, 2006 | 05:56 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
I am having the exact same problem right now. I'm taking my new 58mm TB to a machinist to trim down the lowest cable guide. I imagine I will have to trim the 90* elbow as well, like earlier stated. Hopefully Wed I can give you the size of that hole on the end of the rail, going to take it to a hydraulic place to get the exact fittings I will need. If you come up with anything until then plz post it!
Old May 29, 2006 | 05:59 PM
V6sucker's Avatar
Engine: blown up
standard -6 male o ring pipe thread is 9/16"
I had to call up summit and he gave me one that worked just fine.
Old May 29, 2006 | 10:24 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
i just did a little bending and grinding and made it work. on a side note, anyone know what thread the schrader valve is? i need to replace it with an AN fitting for my under cowl mounted fuel pressure guage
Old May 29, 2006 | 11:29 PM
V6sucker's Avatar
Engine: blown up
should be a standard 1/8" NPT.
Old May 30, 2006 | 07:30 AM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
That's correct, I believe the size is also mentioned in the instructions, also to use teflon on the threads (no O-ring there.)
Old May 30, 2006 | 09:56 AM
V6sucker's Avatar
Engine: blown up
thread sealer is better.
I have found teflon to leak under higher fuel pressures.
Old May 31, 2006 | 04:13 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
ok thanks guys, i bought used so i dont have the instructions for it
ASE doc
Aug 25, 2015 09:14 AM
355tpipickup
Aug 22, 2015 06:06 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
