Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Super Ram and Fuel pressure regulator
Old May 31, 2006 | 10:27 PM
primo's Avatar
I need to replace my Fuel pressure regulator on my super ram motor, I will hate to disassemble the intake. It was a pain to put it together.
Is there a way to replace the fuel regulator without taking the intake apart?
Thanks,
Old May 31, 2006 | 11:05 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I've done it before but it depends if you have torx screws or regular hex screws on your FPR. I found having hex screws makes it easier to do. Still takes a little more time but sure beats having to pull off a Superram.
Now I think about probably allen head screws would work even better and give more clearance for the tool.
Old Jun 2, 2006 | 07:59 AM
primo's Avatar
Thanks, is there anything to wachout for?
Old Jun 2, 2006 | 10:46 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
I've tried to pull mine off. Had no luck because of the torx screws.
I've gotten good at taking off the pizza box 3-4 hours
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
