Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR install issues center bolt holes...
Old May 19, 2006 | 07:49 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
OK, I got the intake, and was going to use the old style heads untill I saw that they were missing several of the bolt bosses for the serp set up.
So I put the stock L98 heads on to find the 4 center bolts are at different angles. I know holley makes the adapter kit, but I am really not wanting to spend some 70 bucks (delivered) for this.
So the question is who has had this same issue and what did you do to solve it on the cheap...
Old May 19, 2006 | 09:29 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The HSR isn't slotted for both patterns?? You gotta be kidding me.
-- Joe
Old May 19, 2006 | 10:48 PM
V6sucker's Avatar
Engine: blown up
-- Joe
slotted yes.
But the 4 center head bolts are at a different angle than the intake.
Meaning the front and rear four tighten down like normal but the center four do not.
Old May 20, 2006 | 05:57 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
slotted yes.
as long as the intake is slotted, it will tighten down fine.. well, that is unless they didn't machine the slot at two different angles. then again, when I converted mine, I didnt machine the slot at two angles and it still worked fine, with 12psi boost.
-- Joe
Old May 20, 2006 | 11:44 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
You need angled spacers (washers) for the center bolts....head to stealthram.com for more info.
But to fix the problem just drill the intake to the required angle.
Old May 21, 2006 | 08:12 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Yep...only for a pre-86 head do you not need these spacers but the for everything else...you will need those washers.
Old May 22, 2006 | 09:45 PM
V6sucker's Avatar
Engine: blown up
I was just looking for a cheaper alternative than 70 something for those spacers that I am sure are marked up some 5X.XX bucks...
anyway I am hoping to fire it up this week!
After nearly 2 weeks of swapping engine (went to a 383) / trans (swapped input shafts with kevlar banded one and 2K stall) tearing down and rebuilding trans... tearing down engine and swapping heads because the pre 86 heads I have did not have a few of the serp bosses drilled... and I did not feel like dealing with that...
But I got most of it back togeather now. Just have to have the drivers side serp. bracket repaired then I can finish the engine/radiator stuff.
I some how lost the factory rubber lines off the frame rail hard lines so I had to buy some of those.
I got the air tubes cut off the 2055's today, will weld them up tomarrow.
Then I need to get the driveshaft back in, and the bulk of the magnaflow cat back up and take it and have the extension tubes made/installed.
I axed the stock water/oil cooler... it was way to big a PITA to remove, was in the way constantly so it is gone. I will install a sandwich adapter and a real one later.
I think I only have one thing I actually need to order and that is a 180 fitting from the pressure regulator... I had bought 2 90's but soon realized one needs to be a 180...
Now just need to put togeather the aldl cable, and get that zif socket in the ECM so I can start tuning with the HSR... Yes I am gonna stay pure maf right now, but gonna do the 749 map conversion soon.
Old May 22, 2006 | 10:04 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Take a look here.
https://www.thirdgen.org/forums/tech...ghlight=washer
I couldn't get them to fit with the TPI but they may work with the open base on the HSR.
The're cheap and the angle was about perfect on them.
There's a couple other suggestions there too.
Good luck with it.
Old May 22, 2006 | 10:57 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
I got my angled spacers for $12 shipped to me from someone over at Stealthram.com
You wanna help me build my ALDL cable??? I've been all over these boards trying to make sense of the schematics but I just can't for some reason.
Old May 22, 2006 | 11:53 PM
V6sucker's Avatar
Engine: blown up
no prob after I find a valid diagram.
I am also making one for the 165 maf though...
Old May 23, 2006 | 12:03 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
true. i think i might just fork out the extra money and buy one.
Old May 23, 2006 | 12:10 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
BTW...check this thread out V6. Might try getting ahold of that guy, he might possibly have a set left or know where to get more cheap. They aren't bad looking, I'm running them w/out problems. $12 shipped to me (I'm Pearl Z on there).
Stealthram.com :: View topic - Beveled washers and bolts...
Old May 23, 2006 | 11:57 AM
V6sucker's Avatar
Engine: blown up
I have been tring to register at that site for a month now... still not getting a reply to join...
Old May 23, 2006 | 12:25 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Hmmmmm.....well I know how that is. Its like that for me for a couple sites that I'd like to join as well.
Email rhinton@stealthram.com ...hes the site administrator over there and see what he says.
Old May 27, 2006 | 07:37 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Save yourself a penny, go to McMaster Carrs website and look for bevelled washers, I paid $2.87 with tax for 8 of them at the time. Very cheap, perfect for what i needed.
Old May 27, 2006 | 07:01 PM
V6sucker's Avatar
Engine: blown up
that is exactly what I did.
I went ahead and ordered 3 (5 piece) packs @ $5.xx, and got them the other day.
Worked great after I got the 1.5" long bolts. 2 spacers per bolt.
So for under $20 I got what I needed. Screw holley and thier inflated BS!
MU HAHAHAHAHA
But as an update to the car, got the headers (2055's) mounted up today.
Got the new serp belt on, did the air delete.
still waiting on 1 180 degree fitting from summit but other than that I think I have everything...
Old Jun 11, 2006 | 11:04 AM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
what's your board name? have you received your activation email? look in your spam folder.
Old Jun 11, 2006 | 07:11 PM
V6sucker's Avatar
Engine: blown up
I got your email earlier today and got it sorted.
Old Jun 11, 2006 | 07:49 PM
mrr23's Avatar
Engine: 360 HSR
good deal. made a change to my admin section and found a bunch of people that hadn't activated their account.
Old Jun 27, 2006 | 05:52 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Do you happen to have a part number for those?
Old Jun 27, 2006 | 11:56 PM
http://www.mcmaster.com/
Part# 92810A120
I had to drill out the holes a little larger. Also, the bevel isn't the perfect angle however the aluminum is soft enough that it will conform for an even clamping pressure.
Only $2.47 for 5, and you only need 4.
Old Jun 28, 2006 | 07:26 AM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Part# 92810A120
Thank you Sir, I do appreciate it!
Old Jun 28, 2006 | 01:59 PM
Actually, I may have been wrong. Are the bolts for a stock TPI 3/8" or 5/16"?
Can't remember and I don't have one to measure.
Measure the stock diameter of your bolts, it's either the 3/8" beveled washer, or the 5/16" beveled washer.
It might be this part # instead: (3/8" alu beveled washer) 92810A130
Old Jun 30, 2006 | 05:09 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Here is what I used..
McMaster-Carr
Attached Thumbnails HSR install issues center bolt holes...-wedgesinstalled.jpg
Old Jun 30, 2006 | 11:07 PM
ED89's Avatar
Car: 89 vet
Engine: v8
Transmission: Automatic
FYI
I installed a stealth ram on my dads 90 vet(w/ custom plenum) wedge washers were not needed.
ED89
Old Jul 1, 2006 | 08:31 AM
McMaster-Carr
Yep, thats a pic of the same beveled washers I used. Only difference is that i used the stock torx head bolt. Cheapest way to fix the issue.
Old Jul 1, 2006 | 10:34 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Yup, iirc I think it was your post from a while back I got the info from.
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Aug 25, 2015 09:14 AM
red90IROCls1
Aug 25, 2015 06:56 AM
blackd-out z28
Aug 15, 2015 08:18 PM
