HSR and fuel... REALLY rich
Car: a car being parted out
Engine: blown up
Transmission: in peices
Ok I have had this car "running" for about 10 days now. Maybe at the most 60-70 miles.
And in that time it has guzzled a good 1/2 a tank.
I know I need to burn a chip for it, and I am ordering the stuff on monday.
However I was just wondering if anyone else had this same result running the stock ECM.
Some stats
Engine 383, 24Lb injectors, auto, 2055's and cat back.
Some stats
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
right now, the injectors are most likely near max trying to feed the 383. the o2 are most likely reading lean and the ECM is adding as much fuel as it can. once you tune this up, the fuel consumtion will come down some.
