Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
holley stealth ram
Old Jun 18, 2006 | 09:52 AM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
holley stealth ram
well i was looking into upgrading my intake since i have full exhaust and tpi sucks so i was gonna just get some ported tpi parts because i thought stealthram cost over $1000. Yesterday i went on thunderracing and seen this
61-534-186 Holley Fuel-Rail Kit w/ Adjustable Regulator for Stealth Ram Intake $224.95
61-7540 Holley StealthRam Intake Manifold & Base Plate. (Stock Fuel Rails not compatible, must use Holley Fuel Rails) $299.99
Are these the only two things i need to buy to install the holley stealth ram on my l98?
also id like to see pics of hsr installed on any thirdgen.
Old Jun 18, 2006 | 09:55 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
lol
Its called search and read the posts that are still on the main page with this topic having been beat to death :-)
Its been covered, most of the good posts on it are still on the first and second pages of this board.
later
Jeremy
Old Jun 18, 2006 | 09:57 AM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
yeah i just seen the stickys at the top of this page
Old Aug 3, 2009 | 12:38 AM
cronsformula350's Avatar
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
Re: holley stealth ram
Well for the Stealth ram, and intake fittings, I had some extra AN fittings and they were Earl, and so was the stainless hose. U will also have to change the water neck, you'll have a lot to choose from, but certain ones can fit the stock hose up top. But you'll fit under a camaro hood, but not a stock firebird one without cutting it up a little inside the bracing area, under the hood in the center.
check out my pics: www.cardomain.com/cronsformula
Old Aug 4, 2009 | 07:57 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
As the original question was asked 3 years ago ( 06-19-2006 )
I figure he got it sorted .
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
