Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR reg. problem
Old Jul 27, 2006 | 04:46 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
HSR reg. problem
Ok, I have my HSR installed, and everything is hooked up, when I crank the engine, my pump comes on and is working properly, plenty of pressure. but no fuel is getting past the regulator. what could be causing this?
Kyle
Old Jul 27, 2006 | 10:29 PM
Z69's Avatar
Z69
Plugged return line or stuck regulator.
I'd think you would have plenty of pressure if the reg won't open.....
Old Jul 28, 2006 | 06:52 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
how much pressure is it showing? i'd imagine it would be pretty high.
Old Jul 28, 2006 | 08:10 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Kyle
Any chance you have the feed on the wrong line?
-- Joe
Old Jul 28, 2006 | 11:43 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
-- Joe
I'm betting they are backwards too.
Old Jul 28, 2006 | 03:38 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
from what i've read, the larger hose, 8an I think it is, is the feed line and the smaller is the return, is that correct?
Old Jul 28, 2006 | 08:02 PM
BOTTLEDZ28's Avatar
Transmission: A4
Check to insure that you have the lines going in the right direction. I have my feed line going into the back of the passenger rail and it returns out the regulator back to the tank. My adjusting screw is also facing out for easy adjustments. The regulators that holley supplies with their HSR kits are known to fail. Most guys replace them with a Kirban regulator. Any FPR for a GN will fit the HSR IIRC.
Old Jul 29, 2006 | 04:45 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
you were right bottled, i had them hooked up backwards, started right up. thanks guys.
Old Aug 8, 2006 | 12:06 AM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Do you have a part number for that Kirban adjustable regulator for the HSR fuel rail?
Old Aug 8, 2006 | 12:43 AM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Buick-6547 Kirbin Perf. Billet Adjustable Fuel Pressure Regulator
Old Aug 8, 2006 | 01:20 AM
transamice's Avatar
Car: 87 GTA t-top
Does this bolt on the holley fuel rails and is -6 AN 3/8 NPT ?
86CamaroDan
Sep 29, 2015 10:08 PM
355tpipickup
Sep 4, 2015 05:32 PM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
