1hotroc
close
Has any one ever had a problem with the stealthram not sealing on the back bridge near the distributor more so on the right side leaking oil. I have resealed the Intake twice with a thick bead of sealer it still leaks. Other than that I love the performance of this Intake.
JP86SS
close
Never had the leak there. I used the cork gasket with gasket maker on both sides and sealed the ends with RTV too. I never trusted the rubber ones to work on the walls.
Be sure its not the oil pressure port on top that is making you think its the intake.
Originally Posted by JP86SS
Never had the leak there. I used the cork gasket with gasket maker on both sides and sealed the ends with RTV too. I never trusted the rubber ones to work on the walls.Be sure its not the oil pressure port on top that is making you think its the intake.
Ditto
JP86SS
close
Forgot to mention to check your PCV stuff. Some blowby will cause high case pressure and keep blowing out the easiest seal. (Always the hardest!)
I've read about some units having the rear area that seals to the valley of the block cast or machined incorrectly so the block and the intake don't line up well. This was on older units.
1hotroc
close
It is an older intake. I bought it when it first came out. What has to be done to make it fit right or do I need a new Intake. Thanks.
Quote:
I think you should call Holley. I think some guys might have got exchanged intakes. You can bring it to a machine shop and have it machined, but why pay more than you have to.Originally Posted by 1hotroc
It is an older intake. I bought it when it first came out. What has to be done to make it fit right or do I need a new Intake. Thanks. -- Joe
I just took mine off and re-sealed it, I used a heavy bead of sealer and it has stopped leaking.
I did not use the cork, just sealer on the block walls.
yes i never had that problen on my,i had this intake since 2004 and the rtv seal looks ok
.TGO Supporter
yep mine seals great, and it is the old style...now only if I can get my valve covers to stop leaking
1hotroc
close
what RTV sealer are you guys using. The brand and color please.
three bond the grey colour one if using three bond make sure to use the cork gaskets for the china wall
I'm partial to Permatex "The Right Stuff" gasket maker. I've never had better success with anything else.
i use the clear stuff or blue. I used a reall big bead and hasn't leaked yet. over a year in the car now or so.
Mine leaked a lot when I first put it on, took it off, cleaned it up and put a nice thick bead of the black rtv and it sealed up great, no more leaks.
I would also check your distributor gasket. I had a nice oil leak from there after swapping heads due to the intake sitting lower. Pull the distributor, remove the gasket, and reinstall it. Use a feeler gauge to measure the distance from the intake to the distributor base. Measure the thickness of the gasket, and do the math.
