Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Stealth ram plenum gasket
Old Aug 23, 2006 | 08:14 PM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
Im trying to chase down some vacuum leaks on my new motor and i started getting to thinking that the chinsey gaskets that holley supplies could be causing a vacuum leak between the plenum and lower intake... anyone else have problems with these gaskets?
Old Sep 2, 2006 | 02:17 PM
BOTTLEDZ28's Avatar
Transmission: A4
Summit sells replacement gaskets for the HSR plenum. Im not sure of the part number but I know they where about $15 for the pair. I ended up ordering 3 sets. Its nice to have spares.
Old Sep 15, 2006 | 01:25 AM
Iroczracer's Avatar
Car: 1989 IROC Camaro
Engine: Stealth Ram 355
Transmission: WC T-5
Axle/Gears: Torsion 3.42 Posi
I was not to excited about that my self..Purchased some good sheet material at the auto shop. Some even resembles intake gasket. Sharpe exto-knfe will make them slick.......
Old Oct 5, 2006 | 12:01 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I had no vacuum leaks, but when I was fixing the oil leak I took off the plenum to clean it up and couldn't find replacement gaskets locally, so I got some gasket material, feels and looks like the same material the stock gaskets are, and cut out some new ones. It was like $7 for the sheet and I can probably get 6 gaskets cut from it. I just couldn't see spending $15 for 2 small gaskets.
Old Oct 13, 2006 | 08:00 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
the holley ones are very cheepo I did the same thing and made my own. not to mention I made the gaskets so they fit the port shape better and the bolt hole line up. which is years ahead of holley
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
