superram and gm 847 cam bad idea?
I'm am thinking about using gmpp's 12370847 cam with the superram the specs. are: I:234 E:242 at .050 duration and lift .539/.558 with a lsa of 112. The heads are afr 190s and the engine is a 415 stroker with around 11to1. Is this cam overkill or would it work pretty well with the accel? Thanks
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
It will work good with that cam on your 415. My 406 is running a 240/240 @.050 and .595/.595 on a 112 seperation and it works well.
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I always dynp both ways to see what the engine is doing without being influenced by the torque convertor.
junkcltr
Aug 2, 2019 11:12 PM
Fronzizzle
Mar 18, 2019 08:29 PM
