Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
ignorant about lt1
Old Mar 22, 2007 | 01:07 AM
bahsarie's Avatar
Car: 89 IROC-Z T-top C&C
ignorant about lt1
all right as the title says im ignorant about lt1's and their abilty to be used with and l98 block. If there are posts that will help me please let me know i searched but could not find anything. Im looking to see if you can swap on a lt1 intake or lt4? or if you can just straight swap on their heads also with an intake? is this a viable cheap hp add? if it is how hp could i expect to gain? thanks all.
Old Mar 22, 2007 | 05:35 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
Re: ignorant about lt1
search. there are intake setups for tpi that are short runner versions that mimic the lt1.
Old Mar 23, 2007 | 11:02 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
An LT1 intake (or LT4 for that matter) need to be "converted" to be able to be installed on an L98 block. Part of the conversion is adding ports to provide a coolant passage between the heads since these intakes don't have any coolant ports. They also have to be drilled for a distributor sine the LTx motors use the Opti-Spark behind the water pump. You can see what I'm talking about by visiting www.lt1intake.com
As for using the LTx heads on the L98, you'd be better off using an LT1 block, too. The coolant passages are the problem. Don't believe you'll be able to do this, at least not easily anyway.
If you're after the sequential injection part of the LT1 you have to use an LT1 harness and ECM (or the 411 LSx ECM and a conversion harness from someone like S10wildside)
Hope this info helps.
And remember - searching can be your best friend around here.
Old Mar 23, 2007 | 11:08 AM
bahsarie's Avatar
I did do a search but thank you for your answer, i appreciate it. I did not realize it was a different gen of engine yet.
Old Mar 23, 2007 | 12:15 PM
vernw's Avatar
Yep, 92-97 is Gen II. Basically the same block as Gen I with some coolant passage (and maybe oiling) changes. Externally the block is the same as a late model Gen I roller block. Or the same as any Gen I block if you ignore the type of rear main seal. All bolt on accessories for a Gen II will fit on a Gen I block.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
