Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
MR Status
Old Mar 26, 2007 | 08:04 PM
5.7iroc-02ws6's Avatar
Car: 1988 IROC/02 WS6
Engine: zz3 crate w/12 psi ATI and stock ls1
Transmission: 700r4 w/2800 stall and m6
Axle/Gears: 3:42 10 bolt-both cars
MR Status
Got the car running.. Needing some tuning I think..
I set the base timing around 7 degrees and it jumps to around 20 w/the EST wire hooked up.
Running 30lb Inj's and it smells pig rich so I am sure I will need to get a chip made..
Anybody else encounter this---I removed EGR provisions and 9th injector completely and I am YET to get a SES light?? What is up w/that?
I still think I am going to have Ed Wright make me a chip.... More to come!!
Old Mar 27, 2007 | 07:52 PM
Re: MR Status
Ran it tonight.. pulls REALLY nice up top... It just kept climbing at 6k and I figured better let off...
I got a '33 and 42' code tonight.. MAF is due to too much airflow at low rpm's and 42 I am not sure... Says the HEI unit per my book?? Anybody??
Old Mar 27, 2007 | 09:06 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: MR Status
Sounds like its time for speed density with that setup. The MAF is being totally overwhelmed by it. Also, with the 30's, you need to scale back the injector constant to match. That will clear up the fueling.
jo88gta
Oct 27, 2002 09:18 AM
joker37
Jul 16, 2002 02:31 PM
cg91ta
Aftermarket Vendor Review
Apr 17, 2002 11:28 AM
mmaker
Jun 1, 2001 11:58 PM
WECoyote
Feb 19, 2001 10:38 PM
