LT1 intake and intake tube
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
What did you LT1 intake conversion people do for a intake tube?
Mine hits the belt tensioner and almost touches the serpentine belt.
Car: '91 GTA
Engine: 421sbc
Re: LT1 intake and intake tube
Anyone with a LT1 intake, please help.
Being that the mini-ram is very similar, I am sure the mini-ram guys could help as well.
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
lb9gta,
Do you mean something like this;
http://store.summitracing.com/partde...5&autoview=sku
If so you can probably have a muffler shop fab up one for you with a bung for the mani temp sensor.
Rabi C.
Rabi C.
Car: '91 GTA
Engine: 421sbc
I tried using ABS pipe, unfortunately they don't make a 3.5" pipe
Would a newer lt1(93 and up) work for me? Does the intake tube direct over to the passenger side like mine?
Car: 88 Formula 350
lb9gta,
I can't see why not. The tubing is simply aluminum with a bung welded in. All you should have to do is get a coupler to fit on to your throttle body. Some say that these aluminum pieces tend to get hot through the heat of the engine. If this is something that you are worried about too then an abs tube would work or the best would be one made out of carbon fiber but those are tough to nail down.
I'd like to find one myself !!
It should work out just fine over the passenger side like yours is now.
Rabi C.
Rabi C.
Car: '91 GTA
Engine: 421sbc
I ended up using ABS pipe.
It's ok and works but I'll have to get something better in the future
Car: 88 Formula 350
LB9GTA,
Its much easier when your SD ! So wheres your battery?
Rabi C.
Rabi C.
1992 Trans Am
May 10, 2023 07:19 PM
92projectcamaro
Jan 18, 2016 08:00 AM
