Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
can I use this tb on HSR????
Old Jul 4, 2007 | 02:20 AM
88iroc-Z's Avatar
Car: 88IrocZ,90 454SS, 86GN, 62Bubbletop
Axle/Gears: 4:10
Can I use a NOS part #20360NOS throttle body on my 88 iroc if I go with a HSR?
I am planning a build, and I would like to use this throttle body being that it is 58mm and also has built in nitrous passages, but I did not know if it could be used since it was for LT1's. I kno wthe plates are the same, but will I be able to use this one with my stock throttle linkage?
thanks
-Daniel
Old Jul 4, 2007 | 11:00 AM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Re: can I use this tb on HSR????
I dunno if this will help you any. Proffesional Products sells there throttle bodys for use on L98 and LT1's. The include another linkage with the kit because they do vary. Sorry not much help but might get you in the right direction.
Old Jul 4, 2007 | 10:37 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
It might actually be worthwhile to ask this question on the LTx/LSx engine swap forum, as you'd have a higher % of people who have experience with the LT1 TB... Sorry I don't have an answer myself, but perhaps that'll help.
86z89iroc
Oct 5, 2015 01:04 PM
86CamaroDan
Sep 29, 2015 10:08 PM
mike22115
Sep 28, 2015 04:49 AM
BBSDesigns
Sep 22, 2015 03:08 PM
355tpipickup
Sep 4, 2015 05:32 PM
