Can the Holley AFPR be repaired?
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I recently found out the AFPR I bought off of a member here doesn't work. Rather than spend $100 on one that works, can the Holley version be repaired?
Re: Can the Holley AFPR be repaired?
If it's not physically damaged metal wise, get a replacement diaphragm and motor on. There's not much to them other than a billet cap, spring, the screw in dial, the screw in brass vacuum fitting and the diaphragm.
I don't know where you'd get a replacement diaphragm though as that was the only part I heard of that goes on those.
Car: 86 T/A
Engine: HSR 355
Even if Holley would sell it separately I'm not sure I'd trust it.
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Hopefully better late than never.
I fixed mine by getting a stock diaphragm/spring assembly out of the junkyard, and cut the stud off that captured the stock spring (it's way too long for the Holley unit). Using the stock diaphragm, I reassembled the Holley unit with all other Holley parts, and it works great. Turn the ****, watch the fuel pressure go up and down, just like it should.
Good luck
TA
Good luck
TA
Car: 85-Vette
Engine: 406ci
Transmission: TKO-600
Axle/Gears: 3:45
No way that I can see, the perimeter of the can is mechanically formed so that it cannot be opened unless you cut it open,, buy a Kirban and be done with it!
Or if you have your receipt, Holley will replace it for free.
Car: 92 Formula
Engine: 383 248/256 cam
Transmission: 700r4 3500 stall
Axle/Gears: 9" 3.89 gears detroit locker
Might be better off buying a fpr for a Grand National although it's not adjustable.
2012sergen11
Oct 13, 2015 07:38 PM
Royal_Z
Sep 30, 2015 08:45 PM
