Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
schrader valve??
Old Sep 3, 2007 | 01:52 PM
emtcee's Avatar
Car: 67 camaro
Engine: 383 accel dfi
Transmission: t56
schrader valve??
anyone know where i can get one for the holley stealth ram fuel rail???i need one so i can hook up my fuel pressure guage as i am having a fuel related problem...thanks
mike
Old Sep 3, 2007 | 04:14 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: schrader valve??
are you using a fuel pressure gauge designed to check the TPI style schrader valves?
I know of a place you can get one to fit that HSR rail. TPI GM style are different from the HSR schrader valve. Grainger refrigeration makes 1/8npt-to 4AN flare schrader valves so you can just screw them into the holley rail.
else you can buy a cheap summit racing liquid filled pressure gauge (1 1/2 inch) and a 1/8npt to 1/8npt 90 degree elbow fitting to keep a gauge on the rail at all times like i did
Old Sep 3, 2007 | 06:44 PM
emtcee's Avatar
Car: 67 camaro
Transmission: t56
yeah i am looking for a gm style valve...so you say grainger has it huh??i will have to check them out...thanks
mike
Old Sep 3, 2007 | 07:21 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Yep, grainger..
http://www.stealthram.com/phpBB2/viewtopic.php?t=173
http://www.grainger.com/Grainger/pro...793365&ccitem=
Old Sep 3, 2007 | 07:36 PM
emtcee's Avatar
Car: 67 camaro
Transmission: t56
cool,thanks for the replies guys...i will have to order them,,
mike
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
BOOT77
Sep 16, 2015 08:37 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
