Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
What setup do I have?
Old Oct 18, 2007 | 09:51 PM
nbays1975's Avatar
Car: 88 GTA
Axle/Gears: 10 bolt rear w/3.73 richmond gears
I bought my new TA a couple of months ago and recently started doing some PROM tuning. This led me to disconnect my Cold Start Injector. Problem is, I can't find it! My tpi setup is definately not standard and I have been unable to figure out what it is. It is a ram air setup and there are no runners. There is just a big square box on top of the engine (made by SLP). I'll attach a pic. If anyone could tell me what this is and how it would affect engine performance/tuning, I would be very appreciative.
Nick
Old Oct 18, 2007 | 10:28 PM
1bad86z28's Avatar
Car: 86 I.R.O.C.
Engine: 40 over TPI 305
Axle/Gears: 3:73
Re: What setup do I have?
From what I can see in the picture, it looks like a stealth ram or short ram setup. Like this.......
As far as the cold start injector, I don't think that intake has a spot for one, but if it does it will be on the drivers side. The plate that says SLP is just a bolt on plate, it doesn't really mean that there is SLP parts. I bought a BBK throttle body from SLP and it says BBK on the nameplate.
Old Oct 19, 2007 | 08:46 AM
nbays1975's Avatar
Car: 88 GTA
Thanks for the reply. I guess I'm going to have to do some research on stealth ram and see what it does for me
Old Oct 20, 2007 | 08:50 AM
vwdave's Avatar
Looks like a Holley Stealth Ram to me.
If you look at the plenum (the box) is there like, 4 allen head bolts holding it down? Is there a few pipe threads in the back of the plenum for vacumn and such? Those are the easiest ways to tell.
Old Oct 20, 2007 | 07:30 PM
nbays1975's Avatar
Car: 88 GTA
There are 4 allen bolts on the top of the plenum. I'm assuming its a HSR then. Thanks for all your input. Now if I can just figure out how to tune this thing.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
