Most torque other then TPI?
Car: 1991 Firebird
Engine: 383 stroker
I'm running an HSR now and was considering swapping to a different MPI manifold for a little bottom end (too expensive to maintain a good A/F at high revs these days
) I was hoping to not break the bank and wanting to avoid a TPI setup. Anyone know of any MPI manifolds that are a dual plane design and single plane?
) I was hoping to not break the bank and wanting to avoid a TPI setup. Anyone know of any MPI manifolds that are a dual plane design and single plane? Senior Member
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Re: Most torque other then TPI?
The superram will provide you more low RPM torque but I would assume that a properly tuned HRS would be close. What is the problem that you have?
ambainb
Apr 25, 2016 09:21 PM
Sanjay
Aug 12, 2015 03:41 PM
